Dark and Light FreeCAD stylesheets (v1.8a)
easyw-fc
Re: Dark and Light FreeCAD stylesheets (v1.8a)
Post by easyw-fc »
pablogil wrote: I don't know, I just know how to style QT, I'm not C++ or Python coder... :(
Hi, I found a way to get if a StykeSheet is applied and in case list all the attributes
print QtGui.QApplication.style().metaObject().className()    #
print QtGui.QApplication.instance().styleSheet()    # list all applied styles
Then I can manage the button styles :)
Thank you for your nice stylesheets :D
Maurice
pablogil
Post by pablogil »
Maurice
Cool!
I'm happy to found the way :D
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
bill
Post by bill »
Is this a problem with Stylesheets or the Widget itself?
yorik
Post by yorik »
It looks like french :D "touche pas!"
triplus
Post by triplus »
bill wrote:Is this a problem with Stylesheets or the Widget itself?
Hi @bill.
I would say it goes more in the direction of feature request. That is UX element like navigation indicator was never done before yet in FreeCAD and therefore Dark and Light stylesheets don't yet have optimal support for styling it.
P.S. I likely won't be able to have a look before weekend.
pablogil
Post by pablogil »
Yes, that feature has been introduced after the last stylesheet update so it needs a little tweaking... @triplus, could you add an ID to the QPushButton so that I can theme it without interfering the rest of elements? I know where is the problem and it has a difficult solutionif not introducing this new ID...
thanks
triplus
Post by triplus »
pablogil wrote:@triplus, could you add an ID to the QPushButton so that I can theme it without interfering the rest of elements?
Hi Pablo. Try using:
NavigationIndicator
triplus
Post by triplus »
https://github.com/FreeCAD/FreeCAD/pull/672
https://github.com/pgilfernandez/FreeCA ... ets/pull/4
zmp2000
Post by zmp2000 »
Hi I have created a new stylesheet , a darker one that looks like Blender 2.8.
It´s on my Fork https://github.com/zmp2000/FreeCAD/blob ... e-dark.qss
I would like to null if a pull request would be welcome or not?
NormandC
Post by NormandC »
Hello zmp2000,
Welcome here.
That sounds intriguing. Could you please post a screenshot? (I'm replying on my phone) I'm sure users would be interested in your theme.
