Expression doesn't update property correctly
Re: Expression doesn't update property correctly
When dealing with rotations you have to be aware of some things.
Precedence of axis there are no a unique convention but at more than 20. I could post later a link where this matter is discussed.
If you use valued bigger than 1.0 you are not using normalized values.
the gimbal lock problem
the fact that a rotation as a sense if it is limited to a turn (0 - 360 degrees) a rotation of 370 degree is equivalent to a rotation of 10 degree, final position of solid is the same.
When things get hard, I usually use Matrix even if they are not perfect (gimbal lock) they permit to apply rotation in the desired order, but I usually script my work so it is a very low level approach.
Later I will post the link when I have fired up my computing machine. Now I'm using a dumbphone.
Jolbas
Post by Jolbas »
onekk wrote: Tue Dec 06, 2022 6:48 am If you use valued bigger than 1.0 you are not using normalized values.
This problem is there whether I calculate normalized values or not.
It is impossible to use expressions at all on the individual X, Y and Z of the Axis.
Jolbas
Post by Jolbas »
Workaround is to set an expression on the Axis instead. There it is no problem with a non normalized vector.
create(<<vector>>;1;1;1)
But it should work on the individual values too or else the expression button should be removed from them.
First thing, link promised:
https://forum.freecadweb.org/viewtopic. ... 5&start=20
Second thing, here it is working as expected:
see:
with this FC version:
OS: Artix Linux (openbox)
Locale: Italian/Italy (it_IT)
  * QuickMeasure 2022.10.28
  * Assembly4 0.12.4
  * fasteners 0.4.24
  * toSketch 1.0.1
  * Curves 0.6.1
  * Help 1.0.3
Jolbas
Post by Jolbas »
The thing is if you replace the expression with a new one that gives the same result you force a recalculation and for each recalculation you get closer to expected result. Try to replace your expressions with:
1 * 1 / sqrt(2)
1 * 1 / sqrt(2)
1 * 1 * 0
What is your immediate result then?
onekk wrote: Wed Dec 07, 2022 7:52 am Second thing, here it is working as expected
Also note that in your row for Placement it shows [(0.62 0,58 0,58);....
Jolbas wrote: Wed Dec 07, 2022 8:41 am The thing is if you replace the expression with a new one that gives the same result you force a recalculation and for each recalculation you get closer to expected result. Try to replace your expressions with:
1 * 1 / sqrt(2)
1 * 1 / sqrt(2)
1 * 1 * 0
No it is not at least for me:
test_expressions.FCStd
(3.53 KiB) Downloaded 21 times
and:
with 90 degree in Angle and the rotation as above, I will obtain
obj.Placement.toMatrix()
Matrix ((0.5,0.5,0.707107,0),(0.5,0.5,-0.707107,0),(-0.707107,0.707107,0,0),(0,0,0,1))
obj.Placement.Rotation
Rotation (0.5, 0.5, 0.0, 0.7071067811865476)
obj.Placement.Rotation.Axis
Vector (0.7071067811865476, 0.7071067811865476, 0.0)
obj.Placement.Rotation.Angle
1.5707963267948966
At least for me it seems consistent with expected values, see obj.Placement.Rotation.Axis that resemble those printed in the image
Jolbas
Post by Jolbas »
Ok @onekk . So this is not affecting all versions? The main difference is that I have a macOS:
OS: macOS 10.16
Locale: C/Default (C)
  * kugghjul.py
  * dxf-library
  * fcgear 1.0.0
  * __pycache__
  * sheetmetal 0.2.53
  * Curves 0.5.6
  * Assembly4 0.12.4
I get this results from python console. Resetting the Axis first:
>>> obj.setExpression('.Placement.Rotation.Axis.x',None)
>>> obj.setExpression('.Placement.Rotation.Axis.y',None)
>>> obj.setExpression('.Placement.Rotation.Axis.z',None)
>>> obj.Placement.Rotation.Axis.x = 1
>>> obj.Placement.Rotation.Axis.y = 0
>>> obj.Placement.Rotation.Axis.z = 0
Vector (1.0, 0.0, 0.0)
>>> obj.setExpression('.Placement.Rotation.Axis.x', '1 * 1 / sqrt(3)')
>>> obj.setExpression('.Placement.Rotation.Axis.y', '1 * 1 / sqrt(3)')
>>> obj.setExpression('.Placement.Rotation.Axis.z', '1 * 1 / sqrt(3)')
>>> obj.recompute()
True
Vector (0.7499999999999999, 0.43301270189221935, 0.5000000000000001)
onekk wrote: Wed Dec 07, 2022 9:43 am
If you look at the values shown at the Placement line there's still something weird going on.
Jolbas
Post by Jolbas »
I can reproduce similar errors without using expressions but by assigning values to Axis parts in python console.
If I set the axis vector to a non normalized vector:
obj.Placement.Rotation.Axis = App.Vector(1,1,1)
Then I can ask for the RawAxis
obj.Placement.Rotation.RawAxis
Returns: Vector (1.0, 1.0, 1.0)
And the Axis attribute returns a normalized vector
Returns: Vector (0.5773502691896258, 0.5773502691896258, 0.5773502691896258)
This all seems to be good, but if I change one of the Axis parameters a normalization event is applied on the RawAxis. Appearantly before assigning the new value which gives unexpexted result:
obj.Placement.Rotation.Axis.z = 2
Returns: Vector (0.5773502691896258, 0.5773502691896258, 2.0)
And
Returns: Vector (0.2672612419124244, 0.2672612419124244, 0.9258200997725514)
Which is a normalized representation of RawAxis
Jolbas
Post by Jolbas »
@onekk Do you get expected results from python commands above?
