Expression doesn't update property correctly
Jolbas
Post by Jolbas »
I found an issue with expressions on some Placement properties.
In the example file I have two cones. Cone001 has expression cos(90 * Variables.Index) on .Placement.Rotation.Axis.X and sin(90 * Variables.Index) on .Placement.Rotation.Axis.Y. Cone002 has expression create(<<vector>>; cos(90 * Variables.Index); sin(90 * Variables.Index); 0) on .Placement.Rotation.Axis. The two cones should be placed at the same position when changing Variables.Index but on some Indexes Cone001 is placed wrong. The result of each expression seems ok but the Placement property is not updated correctly.
I'm not able at the moment to try this in the development build. It may be related to Issues #7589, #7489, #7390 but they are all in Scetcher
If I edit the expression it sometimes updates correctly but if I change Variables.Index to 4 and then back to 5 the error is back
OS: macOS 10.16
Version: 0.20.1.29410 (Git)
Locale: C/Default (C)
  * kugghjul.py
  * fcgear 1.0.0
  * __pycache__
  * sheetmetal 0.2.53
  * Curves 0.5.6
  * Assembly4 0.12.4
exprossion_error.FCStd
(5.44 KiB) Downloaded 21 times
Re: Expression doesn't update property correctly
Can you reproduce in 0.21?
Jolbas
Post by Jolbas »
chrisb wrote: Fri Nov 25, 2022 9:31 pm Can you reproduce in 0.21?
Yes.
OS: macOS 10.16
Version: 0.21.31097 (Git)
Hash: ccf074008774f1bdfed8fec09ed60e2c0fe77cae
  * kugghjul.py
  * fcgear 1.0.0
  * __pycache__
  * sheetmetal 0.2.53
  * Curves 0.5.6
  * Assembly4 0.12.4
I can reproduce, despite the model showing errors due to some Assembly4 stuff missing. It seems to be the same as issue #7390, at least the workaround is the same: You have to make the expression more complicated, e.g. by including some other property. If I use
cos(90 * Variables.Index) * Radius1 / Radius1
it updates correctly. I have added a link to this topic to the Github issue.
Jolbas
Post by Jolbas »
chrisb wrote: Sat Nov 26, 2022 7:03 am You have to make the expression more complicated, e.g. by including some other property. If I use
That doesn't work. If I change Variables.Index to 4 and then back to 5 the error is there again.
Jolbas
Post by Jolbas »
... but changing from 3 to 5 works ??
chrisb wrote: Sat Nov 26, 2022 7:03 am despite the model showing errors due to some Assembly4 stuff missing.
Here is a file without references to Asm4_libs
expression_error.FCStd
(5.21 KiB) Downloaded 23 times
Jolbas
Post by Jolbas »
A recompute on the wrongly placed helps when the angle step is set to 90°. But if I set the angle to multiples of 45° instead, a recompute just moves it closer and closer to the correct placement. And you need to do a lot of recomputing to get it right.
Made some further tests and maybe it has to do with the normalization of the axis vector. Setting expressions to static values also showing weird results:
Jolbas
Post by Jolbas »
Her is a minimized document showing static expressions gives wrong result: A part with the placement rotation set to 120° and the axis vectors X, Y and Z is all set to 1.0 but in expressions. Expected to have the part aligned with the global origin but it is not
axis_expression_error.FCStd
(3.4 KiB) Downloaded 19 times
Jolbas
Post by Jolbas »
I think I found a pattern and this is what seems to happen:
1. The expression for Axis.X is calculated
2. The axis vector is normalized
3. The expression for Axis.Y is calculated
4. The axis vector is normalized
5. The expression for Axis.Z is calculated
4. The axis vector is normalized but the result is not shown in the property editor
I think the wanted steps would rather be:
2. The expression for Axis.Y is calculated
3. The expression for Axis.Z is calculated
I haven't found the relevant code yet though. Maybe someone else has a clue where to look.
EDIT: It is normalized after Z axis is set too but the property editor is not updated.
Jolbas
Post by Jolbas »
The expected behaviour i not obvious when there is expressions of some of the X, Y and Z parts but not all.
I wonder if the rotation axis vector actually not should be normalized when set. There is a companion quaternion saved along with the axis and angle. And the Rotation.getAxis() function seems to return a normalized vector anyway.
