3mf export broken
mfraz74
3mf export broken
Post by mfraz74 »
Trying to import 3mf files into PrusaSlicer fails with the error "Loading of a model file failed"
This seems to be due to the line:
<object id="1" type="surface">
in the 3D/3dmodel.model file
change it to:
<object id="1" type="model">
and it loads.
Attached 2 files, Working.zip (3mf) loads into PrusaSlicer, Broken.zip (3mf) doesn't. All I changed was surface to model as above.
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
  * sheetmetal 0.2.57
  * Manipulator 1.4.9
  * lattice2 1.0.0
  * fcgear 1.0.0
  * Curves 0.5.8
  * Assembly4 0.11.8
  * fasteners
  * A2plus 0.4.59d
  * ThreadProfile 1.84.0
  * Assembly3 0.11.3
  * VendorParts
Working.zip
Working.3mf
(104.37 KiB) Downloaded 25 times
Broken.zip
Broken.3mf
(108.85 KiB) Downloaded 18 times
mfraz74
Re: 3mf export broken
Post by mfraz74 »
For some reason, it only affects certain exports. Haven't figured out why yet.
mfraz74 wrote: Wed Oct 05, 2022 5:10 pm For some reason, it only affects certain exports. Haven't figured out why yet.
According to the specs model is used for solids, i.e. watertight meshes with no open edges. And surface is used for non-solid meshes.
it might help if you post a sample file that exports fine and another that fails
mfraz74
Post by mfraz74 »
Car Phone Holder-Body.3mf exports fine
Lees.3mf doesn't load into PrusaSlicer
Lees.zip
Lees.3mf
(30.1 KiB) Downloaded 16 times
Car Phone Holder-Body.zip
(32.71 KiB) Downloaded 17 times
Look: https://github.com/FreeCAD/FreeCAD/blob ... F.cpp#L145
The question is whether it makes sense to also use model for non-solid meshes just to allow to load it into PrusaSlicer. What does PrusaSlicer do if it detects a mesh that isn't a solid?
CDY_001
Post by CDY_001 »
I had the same problem in both the export to stl or 3mf types. I made sure that the extrusion "SOLID" attribute is TRUE, then found in the draft of the extrusion, change "Make Face" to "false" and this fix the stl option but 3mf is still not working.
