[Poll] Sketcher: Task panel rework.
EDIT: added a poll. Please vote!
Please see below proposal : 1 - Solver message and Update buttons are removed from a 'Solver message' category and put directly on task panel.
2 - Move "Auto remove redundants" and "Auto update" to 'Edit Controls'
3 - 'solver message' category is removed
4 - Put "Edit controls" as optional (as "Advanced solver" is currently). So if some workflow really need quick access to them, they can still enable them.
5 - Add a 'Settings' icon in sketcher toolbar (or to task panel) to grant an easier access to settings than from menu.
Old post in ux/ui : https://forum.freecadweb.org/viewtopic.php?f=34&t=72240
Support me on Patreon: https://www.patreon.com/FreeCadDevDiary
FreeCad Dev Diary channel:[/b] https://www.youtube.com/channel/UCGMTmJ ... NiPSSEhBHA
Re: Sketcher: Task panel rework.
+1
+1
+1
+1
+1
+1
+1
+1
+1
Suggestion: the settings button is a toolbutton that show those checkboxes that are currently in the widget as menu items and an additional "More..." entry that opens the actual Sketcher settings.
Slightly skeptical about the update button. It makes a certain amount of sense to say "automatically update, but if its unchecked or not working, update now manually". Its also acceptable to have the button in two places if anyone really wants it next to update buttons.
Sorry I'm not sure to get what you mean. Could you please elaborate on your suggestion ?jnxd wrote: ↑Mon Oct 03, 2022 4:42 am Slightly skeptical about the update button. It makes a certain amount of sense to say "automatically update, but if its unchecked or not working, update now manually". Its also acceptable to have the button in two places if anyone really wants it next to update buttons.
Sorry for the ambiguity. I'm saying keep the update button next to "Auto Update" checkbox. Then that line basically says what I said in the quote. If you want you can have the update button in both new and old places.paddle wrote: ↑Mon Oct 03, 2022 9:25 amSorry I'm not sure to get what you mean. Could you please elaborate on your suggestion ?jnxd wrote: ↑Mon Oct 03, 2022 4:42 am Slightly skeptical about the update button. It makes a certain amount of sense to say "automatically update, but if its unchecked or not working, update now manually". Its also acceptable to have the button in two places if anyone really wants it next to update buttons.
About the update button, for consistency should the icon not be the same as the recompute icon?
Looks good
Not against that, but once again be aware of all extra work because the same UI file is used both for Task panel and Preferences.2 - Move "Auto remove redundants" and "Auto update" to 'Edit Controls'
Good. Technically it's a "group box" -- QGroupBox -- I think.3 - 'solver message' category is removed
Why not but the other side. Enable it by default, and offer user to hide it.4 - Put "Edit controls" as optional (as "Advanced solver" is currently) and put it out by default. So if some workflow really need quick access to them, they can still enable them.
Not needed. Preferences editor is fine, and as long as you can optionally have access in the Task panel it's great.5 - Add a 'Settings' icon in sketcher toolbar (or to task panel) to grant an easier access to settings than from menu.
That IMO don't make sense to lighten a part of the UI then clutter another one.
What would really be cool is that user is able to reorganize group boxes order in the Task panel.
Re: [POLL] Sketcher: Task panel rework.
I added a poll. Please vote. Thanks
Let's do as you say for now, and we'll submit it for a vote later as it doesn't interfer with main proposal.
I voted yes, but yes and no are not enough options for this topic IMO, we can go further than the changes proposed here. This is my suggestion:
• ditch both the solver messages and edit control group boxes
• solver message is shown directly in the dock widget with the icon only update button as in paddle's muckup
• all the checkboxes are moved into a menu accessed through an "Options" toolbutton, placed besides "Close"
• the menu has a "Set grid size (Current: %f mm)" entry that launchs a widget to set gridsize *
• ditch the "rendering order" widget, offer quick access to Sketcher preference page in this menu instead
with this we save A LOT of vertical space without really loosing functionality, having to click a toolbutton to access those checkboxes is not a downgrade IMO, most of the time I have the edit controls widget collapsed and have to click then set whatever I need then click again to hide. IMO when sketching the most important stuff in the task widget are the solver messages and the element and constraint lists, everything else is nice to have every now and then but a nuisance most of the time.
* ideally in the future we can make the grid autoresize according to zoom level and viewport size and we can just remove the grid size option then
