[Feature Request] Curved slot tool in the Sketcher
NewJoker
Post by NewJoker »
curved slots are quite common in machine design and yet FreeCAD has a tool only for straight ones. Two years ago a user shared his macro for curved slots but it was abandoned: https://forum.freecadweb.org/viewtopic.php?t=43630
I think that it would be great to have a tool for curved slots implemented in FreeCAD. Drawing them manually is really tedious: https://youtu.be/hFnM78IVjkE?t=3717
curved slot.png (21.22 KiB) Viewed 1131 times
What are your thoughts about this ? Such a tool could operate similarly to arc drawing tools - a user would be able to draw it based on 3 point arc or arc from center.
drmacro
Re: [Feature Request] Curved slot tool in the Sketcher
Post by drmacro »
You can have a look at ArcSlot here: https://github.com/macdroid53/FreeCADScripts
I even include an icon so you can add it your toolbar in Sketcher. ;)
User extensible software is the bees knees. :mrgreen:
NewJoker
Post by NewJoker »
@drmacro Thanks, I haven't seen it. I would still prefer a built-in tool since curved slots are very common but a macro is fine for a start.
A rounded rectangle tool was implemented in 0.20 so maybe you could extract the script for curved slots from that repository and add it to Addon Manager ?
NewJoker wrote: Fri Sep 30, 2022 10:22 am curved slots are quite common in machine design and yet FreeCAD has a tool only for straight ones.
I've seen something similar discussed and probably implemented in Path WB.
You could make a "Feature Python Object" with:
Slot Center (center of the slot, ie)
Slot Center of curvature (with "Slot Center" it will define "circle radius" of the center line)
Slot angle (it will define "portion of circle you have to obtain")
Slot width
Something similar to this script:
20220930-slot.py
(3.12 KiB) Downloaded 30 times
paddle
Post by paddle »
+1
I already made this tool in c++: https://youtu.be/OBmrKX8_K1Q?t=302
It's still pending review and should come after tool setting merge.
NewJoker
Post by NewJoker »
paddle wrote: Sat Oct 01, 2022 12:20 pm I already made this tool in c++: https://youtu.be/OBmrKX8_K1Q?t=302
Great, thanks for letting me know :-)
wieszak17
Post by wieszak17 »
Generally +1, but... I think all such tools (rectangle, centered rectangle, rounded rectangle, create regular polygon and slot(s)) should be dropped from FC code and replaced by one universal tool "Insert predefined sketch fragment" plus library (user editable) of definitions for such things. So when next person wants another common element one could just add definition to file (for eg. by creating simple sketch and importing it as that element).
NewJoker
Post by NewJoker »
wieszak17 wrote: Sat Oct 01, 2022 12:47 pm Generally +1, but... I think all such tools (rectangle, centered rectangle, rounded rectangle, create regular polygon and slot(s)) should be dropped from FC code and replaced by one universal tool "Insert predefined sketch fragment" plus library (user editable) of definitions for such things. So when next person wants another common element one could just add definition to file (for eg. by creating simple sketch and importing it as that element).
This could make sense for really uncommon shapes (some fancy polygons, for instance - people ask for them from time to time) but for such important geometries like rectangles and slots, I would definitely stay with the current approach, used in all CAD programs.
Paddle’s approach is the way to go in my opinion. He groups tools and thus reduces the number of toolbar buttons by turning additional variants of sketcher geometries into options for more general tools. So for example there will be one rectangle tool and options to draw it from the center or with rounded corners and so on.
wieszak17
Post by wieszak17 »
Well, they are still same thing. Such universal tool should have some grouping ability anyway to be user friendly, so just some shapes could be marked 'core' and maybe cannot be deleted from library. One could place on toolbar buttons with specific shape or with group of shapes, and by default core groups are added. This way you have one code to implement all this shapes.
If the tool is generalized it will suffice to add a custom menu item that will load an external sketch, (maybe in the document itself), probably if the reference point is in a predictable place like the sketch origin (it is easy to code a polygon around his center).
Only a suggestion.
