Project geometry in assemby (A2Plus)
I want to project hole from one part to another in A2Plus module. Do you have any ideas how to do it? In attachment there is preview what I want to do
- screen.png (26.53 KiB) Viewed 875 times
Re: Project geometry in assemby (A2Plus)
Sorry I don't get it... maybe there is any video how to do it?
I need to project holes from hinge to plank.
Try: PartDesign_ShapeBinder#Example.
A similar solution can be achieved with PartDesign_SubShapeBinder.
I tried with PartDesign_SubShapeBinder but with no success. The description of process you wrote is not cleart for me
Please explain where you get stuck, and post your model. Note that when using a PartDesign_SubShapeBinder step 11 must be skipped but the rest of the procedure should be the same.
In attachemnt there is model with parts. I want to do a hole (or pad in shape of hole) in part withou it (projected from part with hole):
I have error :
Cannot use this command as there is no solid to subtract from.
Ensure that the body contains a feature before attempting a subtractive command.
I have error :
- assembly.FCStd
- (26.99 KiB) Downloaded 9 times
- 2.FCStd
- (13.91 KiB) Downloaded 9 times
- 1.FCStd
- (16.17 KiB) Downloaded 7 times
- Zrzut ekranu 2022-09-26 o 12.19.17.png (29.31 KiB) Viewed 594 times
You have to modify, the individual parts then update them in the assembly.
The error, from before is because there is only a sketch in the body (no solid.)
But how to modify indyvidual part? The binder and the new Body with sketch are separated from parts.
- Zrzut ekranu 2022-09-26 o 15.54.59.png (104.39 KiB) Viewed 525 times
- adrianinsaval
A2Plus can't do in context editing AFAIK, you have to edit the component separately in it's original file.
