[SOLVED] Slackware 15 and FreeCAD 20.1 AppImage
symbolicM
Post by symbolicM »
I'm new to Slackware so this may just be my ignorance but I noticed when upgrading Slackware 15 (installed from live USB) with security fixes that FreeCAD AppImage no longer launched.
Long story short; I am now able to launch the latest FreeCAD AppImages if I run it via sudo.
https://forum.freecadweb.org/viewtopic. ... 04#p625479
Recording my experience here in case anyone is on a similar path.
The situation is obviously not ideal from a security standpoint. Any advice appreciated.
___
ordinary by design
Re: Slackware 15 and FreeCAD 20.1 AppImage
have you tried running with the --write-log parameter and looked at the resulting log file? Have you checked that you have correct permissions in your ~/.config/FreeCAD and ~/.local/share/FreeCAD directories? Does it work if you run with another user?
symbolicM
Post by symbolicM »
Thanks for the prompt.
~/.local/share/FreeCAD/FreeCAD.log reads — in pertinent part — as follows:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Could not find the Qt platform plugin "wayland" in ""
Log: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, minimal, minimalegl, offscreen, vnc, webgl, xcb.
System settings show:
Operating System: Slackware 15.0
KDE Plasma Version: 5.23.5
KDE Frameworks Version: 5.90.0
Qt Version: 5.15.3
Kernel Version: 5.15.38 (64-bit)
Graphics Platform: Wayland
Processors: 2 × Intel® Core™2 Duo CPU E7500 @ 2.93GHz
Memory: 3.7 GiB of RAM
Graphics Processor: Mesa DRI Intel® G41
I don't know where the iso build is looking.
___
ordinary by design
symbolicM
Post by symbolicM »
https://www.linuxquestions.org/question ... ost6381196
Running the desktop in an X11 environment or even wayland, in place of full wayland allowed the AppImages to launch without issue.
This issue is solved and will be marked accordingly.
___
ordinary by design
