Is there any progress in making this available?user1234 wrote: ↑Thu Sep 15, 2022 5:58 pm Best concept for FreeCAD clearance: https://www.youtube.com/watch?v=wrOP7sLqwiM.
@ickby
Sadly.
I understand what you mean and in a commercial environment with a staff of payed programmers, there could a decision be made what to do first. Alas, the situation is different here. The question is here, if changing something makes FreeCAD better, and not if it would be even better to change something else.freedman wrote: ↑Mon Sep 19, 2022 3:39 am Changes like these could be done later after FreeCAD is fully functional, then someone could branch the program and add all the visibility options they can think about. FreeCAD Master should be optimized for speed, the fast engine that can be used for many things.
Realthunder appears to be a really good programmer and after a couple years he still has issues with making the panels and screens work correctly. That's enough to make me nervous. Options are good and could work.More often than not this type of things are implemented as an option. Don't like it? Just disable it.
Yes, one small screen change probably won't slow things down but I have noticed that once someone gets into the code and starts changing things then the community chimes in and says, how about this, how about this, and this.....Besides that, this kind of UI stuff is unlikely to be a significant slowdown IMO, the bottleneck is in occt, not in the UI.
