Helix computing very slow. How to do performance code changes?
psommerfeld
Post by psommerfeld »
I'm doing designs where I need to render screw threads. A single thread, drawn as a helix path, might take 20 seconds to render. Can't imagine a design with 20 of them!
I'm seriously thinking about doing some code profiling. Who to talk to about the details of FreeCAD compute implementation? Who/which forums can I go to to get more info about software and realtime profiling details?
I looking quickly at the source, seems like TopoShape.cpp does the compute, which passes it on to OpenCascade.
I wonder if OpenCascade takes full advantage of SIMD processing in Intel/AMD/M1 processors?
Thanks!
Peter
user1234
Re: Helix computing very slow. How to do performance code changes?
Post by user1234 »
psommerfeld wrote: Sun Aug 14, 2022 4:47 pm I'm doing designs where I need to render screw threads.
I hope only for printing and not for engineering and drawings, since that is a nogo in CAD in general. But i would assume, that you have set your angular defection and deviation too small. For me a helix works in notime.
Greetings
user1234
psommerfeld
user1234 wrote: Sun Aug 14, 2022 4:50 pm I hope only for printing and not for engineering and drawings, since that is a nogo in CAD in general. But i would assume, that you have set your angular defection and deviation too small. For me a helix works in notime.
I'm doing some designs for 3d printing that include screw-type fastening. What other option is there to design them? I'm new to FC, and CAD of this type in general.
The attached project takes about 17 seconds to recompute a small change in length of the helix, on a Mac M1. It takes over 45 seconds if I lengthen the helix from 15 mm to 25 mm. Am I doing something wrong?
test helix.FCStd
(733.49 KiB) Downloaded 16 times
Screen Shot 2022-08-14 at 1.01.31 PM.png (174.76 KiB) Viewed 1006 times
user1234
Post by user1234 »
psommerfeld wrote: Sun Aug 14, 2022 5:45 pm I'm doing some designs for 3d printing that include screw-type fastening. What other option is there to design them?
No, for that it is the purpose. Since you wrote, that you want to do many of them, i thought you make a screw library.
There is no project attached, only a screenshot. But as i wrote, try to set the your angular defection and deviation higher. Many time in recalculating goes in the meshing the representation.
Greetings
user1234
Syres
Post by Syres »
I tested using your file and it take 14 seconds to do any change to the thread. I would definitely look at the Fasteners Wb, the M4 default thread is configurable with custom pitch, length, left hand/right hand and it's way quicker at updating, like 14 times quicker. The wb has in it's Preferences settings a 3D printing scale function applied to all threads/fasteners created.
user1234
Post by user1234 »
I have overseen the file. It takes 9 seconds for me. But when the thread does not overlap in front of the bolt, it takes only 7 seconds. I assume cutting it out would be a little bit faster.
Greetings
user1234
ThanklessLiving
Post by ThanklessLiving »
The visual clout of having physical threads is quite irrelevant compared to conveying the information that the threads are there. For the rendering, replace your thread with a cylinder of the thread's major diameter and a chamfer on the end, and perhaps attach to it a detail image from your model to show the threads as "zoomed in".
Jee-Bee
Post by Jee-Bee »
I would suggest buy some thread cutting dies and some taps they work always. Less difficulties to create in FC, less difficult to print ...
Shalmeneser
Post by Shalmeneser »
You should use the axis / symmetry.
 \_Body (Body)
    \_Pad (Pad)
    |  \_frame anchor (Sketch)
    \_Pad001 (Pad)
    |  \_shaft (Sketch)
    \_AdditiveHelix (AdditiveHelix)
       \_Sketch002 (Sketch)
test helix_SHALM.FCStd
(106.54 KiB) Downloaded 10 times
If you have many threds to model, then using Fasteners workbench is very useful, because you can control thread modeling with a single parameter. And using expressions provides a possibility to switch them off while modeling and then switch them all on in one single go as a final step.
