[Bug] Add-ons manager stops.
fcaduser
Post by fcaduser »
Hello.
When I try to launch the add-ons manager it systematically stops during the update process (always at the same point about 70%, it very seems).
1) I see no hint about the error in the terminal.
2) https://github.com is accessible from Firefox.
Any idea ?
OS: Debian GNU/Linux 11 (bullseye) (GNOME/gnome)
Version: 0.21.29998 (Git)
Hash: 7a1c9303d39ad82199f23dac88e26bc91d4282c1
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Locale: French/France (fr_FR)
  * fasteners
  * fcgear
  * A2plus 0.4.54b
  * Curves 0.3.0
  * sheetmetal 0.2.49
fcaduser
Re: [Bug ?] Add-ons manager stops.
Post by fcaduser »
Just in case... I've just purged :
"~/.local/share/FreeCAD"
But it did nothing. My add-ons manager is broken.
Look here where the helper files are according to the XDG specification: https://wiki.freecadweb.org/Release_notes_0.20#Core
Syres
Post by Syres »
I'd target clearing the cache initially but if none of those fix it please raise @chennes.
fcaduser
Post by fcaduser »
1) I purged everything :
rm -rvf ~/.cache/FreeCAD ~/.local/share/FreeCAD ~/.config/FreeCAD
2) I've removed ~/.FreeCAD long time ago, nothing still lingering here.
3) Same symptom except I have now a tiny information, it stops and shows the message : "icon downloaded FOR "frame" "
Syres
Post by Syres »
fcaduser wrote: Tue Aug 09, 2022 10:56 am 3) Same symptom except I have now a tiny information, it stops and shows the message : "icon downloaded from "frame" "
With FreeCAD closed, in src\Mod\AddonManager\AddonManager.py at line 161 change from:
        ADDON_MANAGER_DEVELOPER_MODE = pref.GetBool("developerMode", False)
        ADDON_MANAGER_DEVELOPER_MODE = pref.GetBool("developerMode", True)
and save the updated file, start FC and without opening any file run the AddonManager. This will give @chennes some additional information hopefully. Copy the output from Checking network connection... onwards into your next reply, my output looks like:
12:41:15  Checking network connection...
12:41:16  GitHub's zen message response: Non-blocking is better than blocking.
12:41:16  Package AnimationFreeCAD: Adding dependency on blinker
12:41:16  Package AnimationFreeCAD: Adding dependency on docutils
12:41:16  Package AnimationFreeCAD: Adding dependency on nine
12:41:16  Package Assembly3: Adding dependency on numpy
12:41:16  Package Assembly3: Adding dependency on py-slvs
12:41:16  Package Beltrami: Adding dependency on Curves workbench
12:41:16  Package BIM: Adding dependency on Arch
12:41:16  Package Curves: Adding dependency on numpy
12:41:16  Package Curves: Adding dependency on scipy
12:41:17  Package FEM_FrontISTR: Adding dependency on FEM
12:41:17  Package frame: Adding dependency on scipy
12:41:17  Package ImportNURBS: Adding dependency on rhino3dm
12:41:17  Package InventorLoader: Adding dependency on Part
12:41:17  Package InventorLoader: Adding dependency on Draft
12:41:17  Package InventorLoader: Adding dependency on Sketcher
12:41:17  Package InventorLoader: Adding dependency on SheetMetal Workbench
12:41:17  Package InventorLoader: Adding dependency on olefile
12:41:17  Package InventorLoader: Adding dependency on xlrd
12:41:17  Package InventorLoader: Adding dependency on xlwt
12:41:17  Package InventorLoader: Adding dependency on xlutils
12:41:17  Package Plot: Adding dependency on matplotlib
12:41:17  Package Mnesarco Utils does not list any content items in its package.xml metadata file.
12:41:17  Package Ship: Adding dependency on capytaine
12:41:17  Package Ship: Adding dependency on plot
12:41:31  Output from pip -o:
12:41:31    Package            Version Latest Type
12:41:31    ------------------ ------- ------ -----
12:41:31    importlib-metadata 4.11.4  4.12.0 wheel
12:41:31    Markdown           3.3.7   3.4.1  wheel
12:41:31    zipp               3.8.0   3.8.1  wheel
12:41:31
12:41:31
ADDON MANAGER DEVELOPER MODE CHECKS
12:41:31  -----------------------------------
12:41:31  Addon '3D_Printing_Tools' does not have a package.xml file
12:41:31  Errors found in package.xml file for 'A2plus'
12:41:31     * No readme url specified (not required, but highly recommended)
12:41:32  Addon 'animation' does not have a package.xml file
12:41:32  Addon 'ArchTextures' does not have a package.xml file
12:41:32  Addon 'assembly2' does not have a package.xml file
12:41:33  Addon 'Autoload' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'BCFPlugin'
12:41:33     * No readme url specified (not required, but highly recommended)
12:41:33  Errors found in package.xml file for 'Behave-Dark-Colors'
12:41:33  Addon 'BIMBots' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'BIM'
12:41:33  Addon 'bimtester' does not have a package.xml file
12:41:33  Addon 'BOLTSFC' does not have a package.xml file
12:41:33  Addon 'CADExchanger' does not have a package.xml file
12:41:33  Addon 'cadquery_module' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'CfdOF'
12:41:33  Addon 'Cfd' does not have a package.xml file
12:41:33  Addon 'CommandPanel' does not have a package.xml file
12:41:33  Addon 'CubeMenu' does not have a package.xml file
12:41:33  Addon 'cura_engine' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'CurvedShapes'
12:41:33  Errors found in package.xml file for 'Curves'
12:41:33  Addon 'Defeaturing' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'Design456'
12:41:33  Errors found in package.xml file for 'DesignSPHysics'
12:41:33  Addon 'dodo' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'Dracula'
12:41:33  Addon 'drawing_dimensioning' does not have a package.xml file
12:41:33  Addon 'dxf-library' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'DynamicData'
12:41:33  Addon 'EM' does not have a package.xml file
12:41:33  Addon 'ExplodedAssembly' does not have a package.xml file
12:41:33  Addon 'ExtMan' does not have a package.xml file
12:41:33  Errors found in package.xml file for 'ExtremeProDark'
12:41:34  Errors found in package.xml file for 'fcgear'
12:41:34     * No readme url specified (not required, but highly recommended)
12:41:34  Errors found in package.xml file for 'FEM_FrontISTR'
12:41:34  Addon 'flamingo' does not have a package.xml file
12:41:34  Errors found in package.xml file for 'frame'
12:41:35  Addon 'GDT' does not have a package.xml file
12:41:35  Addon 'Glass' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Help'
12:41:35     * No readme url specified (not required, but highly recommended)
12:41:35  Addon 'IconThemes' does not have a package.xml file
12:41:35  Addon Manager: Unexpected 404 response from server
12:41:35  Errors found in package.xml file for 'ImportNURBS'
12:41:35     * Could not access specified readme at https://github.com/KeithSloa/ImportNURBS/blob/master/README.md
12:41:35  Errors found in package.xml file for 'InventorLoader'
12:41:35  Addon 'kerkythea' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'kicadStepUpMod'
12:41:35  Errors found in package.xml file for 'lattice2'
12:41:35  Addon 'Launcher' does not have a package.xml file
12:41:35  Addon 'LCInterlocking' does not have a package.xml file
12:41:35  Addon 'parts_library' does not have a package.xml file
12:41:35  Addon 'Lithophane' does not have a package.xml file
12:41:35  Addon 'MakerWorkbench' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Manipulator'
12:41:35  Errors found in package.xml file for 'Marz'
12:41:35  Errors found in package.xml file for 'MeshRemodel'
12:41:35  Errors found in package.xml file for 'MnesarcoUtils'
12:41:35     * No content items found
12:41:35  Addon 'ModernUI' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'MOOC'
12:41:35  Addon 'NavigationIndicator' does not have a package.xml file
12:41:35  Addon 'nurbs' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'OpticsWorkbench'
12:41:35  Addon 'ose-piping' does not have a package.xml file
12:41:35  Addon 'OSE3dPrinter' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Part-o-magic'
12:41:35  Addon 'pcb' does not have a package.xml file
12:41:35  Addon 'persistenttoolbars' does not have a package.xml file
12:41:35  Addon 'PieMenu' does not have a package.xml file
12:41:35  Addon 'pivy_trackers' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Plot'
12:41:35  Addon 'pluginloader' does not have a package.xml file
12:41:35  Addon 'POV-Ray-Rendering' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'ProDarkThemePreferencePack'
12:41:35     * No email address specified for maintainer 'turn211'
12:41:35  Addon 'Pyramids-and-Polyhedrons' does not have a package.xml file
12:41:35  Addon 'pyrate' does not have a package.xml file
12:41:35  Addon 'reconstruction' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Reinforcement'
12:41:35     * No top-level <version> element found, or <version> element is invalid
12:41:35  Addon 'RemBench' does not have a package.xml file
12:41:35  Addon 'Reporting' does not have a package.xml file
12:41:35  Addon 'retr3d' does not have a package.xml file
12:41:35  Errors found in package.xml file for 'Rocket'
12:41:35  Errors found in package.xml file for 'SearchBar'
12:41:35     * No <classname> specified for workbench
12:41:35  Addon 'SelectorToolbar' does not have a package.xml file
12:41:36  Errors found in package.xml file for 'Ship'
12:41:36     * No readme url specified (not required, but highly recommended)
12:41:36  Addon 'ShortCuts' does not have a package.xml file
12:41:36  Errors found in package.xml file for 'Silk'
12:41:36  Addon 'slic3r-tools' does not have a package.xml file
12:41:36  Addon 'SlopedPlanesMacro' does not have a package.xml file
12:41:36  Addon 'SteelColumn' does not have a package.xml file
12:41:36  Addon 'symbols_library' does not have a package.xml file
12:41:36  Addon 'TabBar' does not have a package.xml file
12:41:36  Errors found in package.xml file for 'ThreadProfile'
12:41:36  Addon 'timber' does not have a package.xml file
12:41:36  Addon 'ToolbarStyle' does not have a package.xml file
12:41:36  Addon 'Trails' does not have a package.xml file
12:41:36  Addon 'WebTools' does not have a package.xml file
12:41:36  Addon 'workfeature-macro' does not have a package.xml file
12:41:36  Addon 'workfeature' does not have a package.xml file
12:41:36  Addon 'yaml-workspace' does not have a package.xml file
12:41:36  Addon 'offline-documentation' does not have a package.xml file
12:41:36  Macro 'FCRotateViewAbsolute' does not have an icon
12:41:36  Macro 'Foto' does not have an icon
12:41:36  Macro 'SolidSweep' does not have an icon
12:41:36  Macro 'DxfToSketchLayers' does not have an icon
12:41:36  Macro 'ExportFem' does not have an icon
12:41:36  Macro 'FemAnimateModeShapes' does not have an icon
12:41:36  Macro 'GetGlobalPlacement' does not have an icon
12:41:36  Macro 'SimpleProperties' does not have an icon
12:41:36  Macro 'TreeToAscii' does not have an icon
12:41:36  Macro 'AirfoilImportAndScale' does not have an icon
12:41:36  Macro 'Draft_Circle_3_Points' does not have an icon
12:41:36  Macro 'EllipseCenter2Points' does not have an icon
12:41:36  Macro 'HalfHull' does not have an icon
12:41:36  Macro 'ParabolaCreater' does not have an icon
12:41:36  Macro 'ScrewMaker' does not have an icon
12:41:36  Macro 'GeodesicDome' does not have an icon
12:41:36  Macro 'Rectellipse' does not have an icon
12:41:36  Macro 'GuiSpacemouseRotationOff' does not have an icon
12:41:36  Macro 'GuiSpacemouseRotationOn' does not have an icon
12:41:36  Macro 'GuiSpacemouseRotationToggle' does not have an icon
12:41:36  Macro 'SplitPropEditor' does not have an icon
12:41:36  Macro 'ViewRotation' does not have an icon
12:41:36  Macro 'SketcherBlockAll' does not have an icon
12:41:36  Macro 'SketcherFixAllPoints' does not have an icon
12:41:36  Macro 'SketcherOffset' does not have an icon
12:41:36  Macro 'TechDrawAnnoTextFromv018' does not have an icon
12:41:36  Macro 'TechDrawMigrateFromv018' does not have an icon
12:41:36  Macro 'TechDrawSymbolsLibrary' does not have an icon
12:41:36  Macro 'TechDrawTools' does not have an icon
12:41:36  Macro 'TechDrawViewSet' does not have an icon
12:41:36  Macro 'MessageBox' does not have an icon
12:41:36  Macro 'pcbway' does not have an icon
12:41:36  Macro 'PlacementAbsolufy' does not have an icon
12:41:36  Macro 'StraightenObject' does not have an icon
12:41:36  Macro 'Rotate ViewAxonometric' does not have an icon
12:41:36  Macro 'FCInfo' does not have an icon
12:41:36  Macro 'Unroll Ruled Surface' does not have an icon
12:41:36  -----------------------------------
12:41:36  Package Mnesarco Utils does not list any content items in its package.xml metadata file.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
  * A2plus 0.4.56a
  * Assembly3 0.11.3
  * CfdOF 1.17.7
  * Curves 0.5.4
  * fasteners 0.3.51
  * fcgear 1.0.0
  * freecad.xray 2022.4.17
  * Manipulator 1.4.9
  * Plot 2022.4.17
  * sheetmetal 0.2.56
  * Silk 1.0.0
chennes
Post by chennes »
@Syres: first, when necessary I'd suggest giving instructions for setting the developerMode variable via the GUI, rather than editing the source code. And second, users should pretty much never need or want that mode enabled. What's needed in this case is to turn on all logging levels.
Chris Hennes
Pioneer Library System
fcaduser
Post by fcaduser »
I dit it. But where is the log output ? I see nothing in the terminal.
Syres
Post by Syres »
@chennes OK, apologies.
@fcaduser have you got your logging set in Edit>Preferences>General>Output window as per below:
The output will be in Report View Pane.
fcaduser
Post by fcaduser »
I don't understand... see the screenshots :
(Only record (="enregistrer") log messages is deactivated to avoid inflation.)
Capture d’écran de 2022-08-09 17-32-24.png (197.22 KiB) Viewed 791 times
Capture d’écran de 2022-08-09 17-34-09.png (149.16 KiB) Viewed 791 times
