My goals: to help my workflow and simplify modeling in PartDesign. Since I'm not a developer I do everything in macros.
The macro; I'm adding one button to create an new sketch with a creation mode (Lock) and the macro will also run/scan periodically to check for alignments.
What happens during the scan of the document; If a sketch has a non-zero AttachmentOffset (X or Y) then a "+" will be added to the front of the name (pic). If a sketch is created using the new Lock mode a "L+" will be added to the name.
A locked sketch can only be created if the prior sketch has a "+" and the new sketch will be created with an identical Support. The macro will scan periodically to verify that a locked sketch has an identical AttachmentOffset (X an Y) to the previous sketch that has the "+".
What I get from this; First, I can see exactly what sketches are not origin based by seeing the "+" as an identifier. Secondly, having the lock feature allows me to have a built-in external geometry location point. The lock guarantees an identical AttachmentOffset for a group of sketches, all based on the first sketch in the group.
In the pic as I scan down I see Sketch001, I know it's off-origin. As I go down further I see Sketch003, It's off-origin also. I see Sketch004 off-origin but I also notice that Sketch005 and Sketch006 are locked so I know they have the same AttachmentOffset as Sketch004.
This allows me to group sketches in specific places, for instance I have an I-beam 10 meters long, I can go to each end and create a set of sketches that are all based on one sketches placement. I can have two groups, one at each end. By using the TIP I can add additional sketches anytime to different sketch groups.
Maybe there is something useful to FreeCAD Master, I never know. It would be nice to have this in code instead of text based.
Sketch attachment and tree view (new concept of sketch groups).
- Locked.png (84.49 KiB) Viewed 600 times
