Piping macro, designing in 3D view "Route5"
I want to use the macro a little more before I release it but here is one design and some pics. The tubing took me about an hour to draw and a couple hours to adjust just right, that might actually be good in terms of 3D CAD.
You can see from the side view there is a lot going on at angles.
- route_3.FCStd
- (280.29 KiB) Downloaded 48 times
- route1.png (363.79 KiB) Viewed 3494 times
- route2.png (216.36 KiB) Viewed 3494 times
Re: Piping macro, designing in 3D view
Interesting, I'm looking forward to your next post regarding this macro.
Regards / Viele Grüße
Max
Max
Re: Piping macro, designing in 3D view "Route1"
Here is a new macro "Route2". It automates many tasks of creating an additive pipe. It will do all the work of creating a map-mode attachment and a basic sketch. It uses map-mode "sectionOfRevolution" so the attachment edge needs to be an arc or circle. Each Additive pipe will have only one sketch in the tree, this is the path or Spine. The path is parametric but it has limits to what it can keep connected when there are many pipe sections.
I have included a starting file but the requirement is very simple; create a sketch with a circle or arc and pad it. I normally pad this very thin (.001 mm) because it is for reference only, it's the face that will be piped. Obviously any face could be piped using the correct attachment rules.
Certain tools will only be available depending on what is selected, a sketch and an Active Body for instance.
Note: Updating to "Route2". Added subtractive piping.
Sketch 3D view
The first checkbox (if checked) allows you to view and create in 3D, including Sketcher, once you get used to this it is very fun. While in Sketcher, ALT key plus the left mouse button allows you 3D rotation in FreeCAD. Sometimes you need to rotate around to the other side to select vertex.
Subtractive piping
If you want to remove material then do subtractive piping. You need to do the same operation as below where we create a pipe i.e make a sketch, pad it thin, this is the pattern for the subtractive pipe.
Pipe building:
Add Pipe or Add Elbow will start a pipe process, a pipe is a straight section and the elbow is a 90 degree section. The spine sketch is created for you to edit the spine path, you can add additional sketch geometry. The dialog turns yellow when in creation mode and the Actions at the bottom of the dialog give you an idea of what to select, you can uncheck the Pipe build checkbox to cancel the pipe.
You need a circular or curved edge and a face selection to build the pipe, once both are selected the dialog will turn bright red, please wait!. Once finished the dialog will change back to normal and you will be in sketch edit mode ready to edit the spine path. Close the sketch when finished and you should have a pipe. You might need to zoom-in to select a face.
Rotator:
Rotator options are for editing when a sketch is selected in the tree. Once a sketch is selected the rotator allows you to rotate the path direction. Turn ccw and turn cw perform the actual rotation. The two Angle adjustments give some options, click on them multiple times to set, one is small increments and the other large. The rotations could of coarse be set manually by using sketch attachment offset.
180 degree sketch changes face sides for sketch Normal-to.
Map reversed rotates the sketch by 180 degrees.
Visibility:
See inside changes visibility of the Active Body. Clicks will toggle back and forth. (Active body only)
See path will show only the sketch segments or back to full viewing. (Active body only)
The See path is useful when editing, once the sketch items are clickable in the 3D they can be identified in the tree to edit.
The first pic shows forms that could be piped. The second pic is a knot I created in about 10 minutes, I'm getting much faster at creating.
Let me know if you have problems with dialog.
Sketch 3D view
Subtractive piping
Pipe building:
Rotator:
Visibility:
- Pipe_flat.FCStd
- (12.13 KiB) Downloaded 35 times
- patterns1.png (141.49 KiB) Viewed 3223 times
- panel1.png (314.46 KiB) Viewed 3223 times
Have you done a geometry check on the resulting pipe solid?(with BOP check enabled)
Outdated, Deleted
Hmm...I have yet to find a construct in FreeCAD that will consistently create good geometry in such cases.freedman wrote: ↑Wed May 25, 2022 2:31 pmNo errors!Have you done a geometry check on the resulting pipe solid?(with BOP check enabled)
I didn't expect errors because the macro doesn't create any geometry it just makes using FreeCAD easier.
Here is a complex shape (pic), No errors and easy to make. I'm running low on time right now but my next feature to add is subtractive piping. I will need to automate face/edge selections inside a solid because FreeCAD has some limitations selecting inside a solid. I really want to be able to make a fluid path inside a 3D printed part.
Thanks
Are the pipes the macro produce following arcs or splines?
They follow spline sketches. Some confusion might be the map-mode, I expected a comment about usage . I found that 'SectionOfRevolution' is very unique in that it creates an attachment that is perpendicular to the object normal. This allows me to create the sketch viewing from the side which is perfect for editing a spline. Once I found this attachment process I knew I could exploit it and do spline editing.Are the pipes the macro produce following arcs or splines?
I have created dozens of models with no issues in stability. The only issues I have seen come from making the radius so tight that the model turns on itself, that can be fixed by spline modification. The only problem I see is if the user needs to add a new pipe in the middle somewhere, you really need to be a pro user to do it.
I'll dig up some of the files that have never worked and you can see if your magic works on them. I have posted about them in the Curves thread several times.freedman wrote: ↑Wed May 25, 2022 3:37 pmThey follow spline sketches. Some confusion might be the map-mode, I expected a comment about usage . I found that 'SectionOfRevolution' is very unique in that it creates an attachment that is perpendicular to the object normal. This allows me to create the sketch viewing from the side which is perfect for editing a spline. Once I found this attachment process I knew I could exploit it and do spline editing.Are the pipes the macro produce following arcs or splines?
https://forum.freecadweb.org/viewtopic. ... 11#p570311
https://forum.freecadweb.org/viewtopic. ... 42#p570642
Here are my results, both pass BOP. I took a little different approach with the 3-way, I created 3 solid trunks and then hollowed them out with subtractive piping. I had a little trouble with the 3_way, there was a BOP error on an outer edge of the solid. I rotated the trunk 2 degrees and the BOP was fine, I guess that's cheating but the angle was random in the first place.
The pipe with angles, well, I feel like I could do that all day with 100% BOP.
I have updated the macro to do subtractive piping but it will have limits, we can't select internal (in solid) faces currently.
- trunk_test.FCStd
- (416.88 KiB) Downloaded 38 times
- pipe_test.FCStd
- (279.91 KiB) Downloaded 31 times
- test_pic.png (185.12 KiB) Viewed 2897 times
Here is another interesting concept of usage, we normally need a bunch of sketches and pad/pocket to do something like this; we have a stair-step solid using only one sketch001 for the pattern, a couple clicks of the macro, set your depth! Again 100% Bop. This took about two minutes to accomplish. Using one sketch has a big advantage.
This was modeled with "Route2", the updated macro with subtractive piping.
I have noticed that TNP can make a big mess using the Piping since all the Spline sketches are attached to edges. I would say don't use this if you need to go back and edit. This should work great when TNP is fixed.
- step_1.FCStd
- (86.84 KiB) Downloaded 27 times
- step_1.png (178.58 KiB) Viewed 2876 times
