[Bug] SIGBUS & SIGSEGV altering spreadsheet parameter
Re: [Bug] SIGBUS & SIGSEGV altering spreadsheet parameter
wmayer wrote: Mon May 09, 2022 1:44 pm So, it must be checked whether all this happens inside SheetTableView::commitData
The implementation of SheetTableView::commitData is
void SheetTableView::commitData(QWidget* editor)
    QTableView::commitData(editor);
and I added a printf() statement before and after QTableView::commitData. Running another test showed that indeed the call of QTableView::commitData triggers the whole time-expensive recompute of the document. I think we should delay the recompute until after QTableView::commitData has been executed.
This is the function that will be triggered when editing a cell. The calling instances are SpreadsheetDelegate::setModelData and QAbstractItemView::commitData.
I think the whole EditRole block should be moved to a separate function that will be delayed until QAbstractItemView::commitData has finished. Additionally there should be an option to disable the call of
Gui::Command::doCommand(Gui::Command::Doc, "App.ActiveDocument.recompute()");
because then a user doesn't have to wait several minutes after each change of a cell. However, the Recompute button must be pressed manually then.
Frank Schrüfer wrote: Mon May 09, 2022 2:11 am The bugreport at qt is: https://bugreports.qt.io/browse/QTBUG-103333
Have you seen the reply to your bug report?
Looks like FreeCAD has a threading problem. I need a smaller testcase than the full application.
I have written a small test application where I simulate a long pending process to update a cell in SheetModel::setData(). When following the procedure I described in the file dialog.cpp it crashes very reliably but may take a while until it does. Sometimes it also prints the warning:
QObject::installEventFilter(): Cannot filter events for objects in a different thread.
which means that it's definitely not a threading problem in FreeCAD.
Can you forward the ZIP file to the bug report, please? And when you are there could you also ask whether it's a good idea to put the time consuming operation into SheetModel::setData() or if it's better to start a single-shot timer and perform the operation afterwards?
Thanks in advance!
QtCrash.zip
(3.93 KiB) Downloaded 18 times
openBrain
Post by openBrain »
wmayer wrote: Wed May 11, 2022 12:35 pm if it's better to start a single-shot timer and perform the operation afterwards?
I find this horrible. :D You should instead use 'QMetaObject::invokeMethod' with a 'Qt::QueuedConnection' type. :)
@Frank Schrüfer ping
Frank Schrüfer
Post by Frank Schrüfer »
wmayer wrote: Wed May 11, 2022 12:35 pm Can you forward the ZIP file to the bug report, please? And when you are there could you also ask whether it's a good idea to put the time consuming operation into SheetModel::setData() or if it's better to start a single-shot timer and perform the operation afterwards?
Thanks, I did as you requested.
My response-times are really bad lately, sorry for that :-)
Ever noticed that things that need your attention tend to have the habit to come in bulk? ;-)
Thanks. So after all it's obviously a bug in Qt.
