[Design] Drawing a wire (inductor) on shapes
I have a following question: I would like to design a inductive element (electronics) build from two parts: a inductive core and a coil. The first part is no ta problem, but the second one already is.
I need any hints how can draw a inductive coil (wire) and then put it in this drawing on a core.
Anyone have any idea how to solve it?
Thanks for the help
Thanks for the help
Re: [Design] Drawing a wire (inductor) on shapes
If the inductive core is a cylinder, then you can use a helix and a sweep. If it has a different shape, you first have to cut a helical shape with the core to get the sweep path. Quite some time ago such coil was discussed here.
The core is a toroid, so it's not as easy as it look for me
The addon macro "3D parametric curve" can create such paths.
Such parameters could do the trick:
- Bildschirmfoto 2022-01-19 um 11.31.26.png (52.43 KiB) Viewed 1966 times
Another idea, not very correct but could be refined:
- ToroidalSpirall.FCStd
- (526.42 KiB) Downloaded 42 times
There already exists a proper macro alongside a Python file (thanks to @tcsut) please see https://forum.freecadweb.org/viewtopic. ... 26#p441300
So you only need to download the first listed ToroidalWinding2.py and then create a new macro file called something like Make_ToroidalWinding.FCMacro which includes the two lines:
You can then adjust the parameters in the Data tab of test2 object for N - turns, a - angle etc.
import ToroidalWinding2
ToroidalWinding2.create('test2')
Thanks. I'll try it out whenever I get able to download the macros's and plugins... for now I get an strange error about beeing unable to connect to wiki to download it (reported as an bug)
So you can't download the attachment below???
- ToroidalWinding2.py
- (3.71 KiB) Downloaded 24 times
downloads perfectly OK for me...?
