OS: Ubuntu 20.04.3 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: e4aad767f452db386659f90139f6527af1fb1640
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
History: I imported an STL file to change hole diameter, Mesh->Import mesh. Then Part->Create shape from mesh. Then Part->Convert to solid. Then Part->Create a copy->Refine. Then created new body and added shape binder, created a Sketch, made a circle referencing that shape binder and padded it in Part Design. Then I Part->Cut to make a hole.
So far it worked. But now if I click on Sketch, FreeCAD silently crashes. If I delete that Cut operation, everything works again.
