How to measure radius
VincentSkerved
Re: How to measure radius
Post by VincentSkerved »
chrisb wrote: Wed Jan 26, 2022 1:13 pm I don't know of any development, but from what I see here in the forum, an improved measurement tool would be appreciated. Besides that there is nothing wrong with using addons. That's what extensible software is about.
Thanks for the reply. I think I will have a look at the code base to see what I could do myself. It is certainly a much larger project than I have been working on before. But I know you look for more devs to help, so I am interested to give it a go.
Nothing wrong with addons. I just think what I am after is something that should be built-in. But that's my view of it, I happily discuss it with you guys, but I think I will do a mock-up or something first.
VincentSkerved
thomas-neemann wrote: Wed Jan 26, 2022 1:15 pm in my opinion, draft line is a quick measuring tool. here's an example
Thanks for the tip, I will try that as well, but I don't think it's really what I'm after.
GeneFC
Post by GeneFC »
VincentSkerved wrote: Wed Jan 26, 2022 12:08 pm Maybe I should ask in the development fourm?
Open Discussion is the appropriate forum for feature requests. But this one has been asked quite a few times.
Gene
Moved to Open discussion.
Zolko
Post by Zolko »
heron wrote: Sun Nov 21, 2021 3:25 pm There is a Measure tool in Asembly4 workbench.
VincentSkerved wrote: Wed Jan 26, 2022 1:33 pm Thanks for the reply. I think I will have a look at the code base to see what I could do myself.
the code for the Asm4 measure tool is here:
https://github.com/Zolko-123/FreeCAD_As ... Measure.py
It's nearly standalone, you should have no difficulty to make a macro out of it.
thomas-neemann
Post by thomas-neemann »
if someone takes the trouble to set up new measurement functions in freecad, it should be possible that e.g. a craftsman can measure this pipe lying diagonally in space with 2 twisted miter cuts in less than 30 seconds
2049.FCStd
(161.94 KiB) Downloaded 27 times
https://www.youtube.com/watch?v=qmuWr6BBBq4
phpBB [video]
Zolko
Post by Zolko »
thomas-neemann wrote: Wed Jan 26, 2022 7:52 pm if someone takes the trouble to set up new measurement functions in freecad, it should be possible that e.g. a craftsman can measure this pipe lying diagonally in space with 2 twisted miter cuts in less than 30 seconds
It might have taken me more than 30 seconds, probably closer to 2 minutes (EDIT: but it also depends on what exactly you want to measure: max length of each tube, length of centerline ...)
thomas-neemann
Zolko wrote: Wed Jan 26, 2022 9:17 pm ...max length of each tube,...
yes, the craftsman needs that to cut the part. with your measure the part would be about 36 mm too short.
the measure here results from a sweep, there is no sketch in which the measure is contained. it is difficult to measure. it also lies at an angle in the room
bambuko
Post by bambuko »
and ... what has all this to do with "measuring radius" ?
you guys are hijackers ;)
thomas-neemann
bambuko wrote: Thu Jan 27, 2022 9:44 am and ... what has all this to do with "measuring radius" ?
sorry, that wasn't my intention. I had understood that it is now generally about new measuring functions in freecad
