.3mf file type
Re: .3mf file type
No.
thomas-neemann
Re: .3mf file type
Post by thomas-neemann »
adrianinsaval wrote: Fri May 27, 2022 9:15 am Is it available for import too?
apparently the free 3d builder can export 3 formats that freecad can import, so it shouldn't be a problem
https://answers.microsoft.com/en-us/win ... 2923f7245b
Re: .3mf file type
It wouldn't be a problem for Windows users you mean
thomas-neemann
Re: .3mf file type
adrianinsaval wrote: Sat May 28, 2022 11:37 am It wouldn't be a problem for Windows users you mean
Yes, that's right, it is mainly intended for the case that someone created the file themselves, or has the person who created it give them a different format.
kborgen
Re: .3mf file type
Post by kborgen »
Edit: From onekk suggestions I added the .3mf as a .zip to circumvent the forum limitations
Let me know if this is incorrect to add on to this thread.
I am not able to export the part as a .3mf. It appears to generate a blank(?) file. I have the attached FC file. I'm not able to upload the .3mf file since it is not one of the supported files for the forum.
Steps I am doing:
1. Select body
2. Meshes -> Create mesh from shape
3. Standard (10um, 3 deg)
4. Right click generated mesh -> export mesh
5. Select .3mf from dropdown
Version: 0.20.28929 (Git)
Hash: 9251480ddb
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
  * A2plus
Island Map Bench.zip
(17.01 KiB) Downloaded 11 times
Island map.FCStd
(43.42 KiB) Downloaded 14 times
Re: .3mf file type
kborgen wrote: Thu Jun 02, 2022 11:41 pm I'm not able to upload the .3mf file since it is not one of the supported files for the forum.
Suboptimal solution could be to rename it with a supported extension and let other users know that the file has to be renamed, or to zip the file.
Usually they work and permit to exchange unsuported extensions.
JohnOCFII
Re: .3mf file type
Post by JohnOCFII »
wmayer wrote: Thu May 26, 2022 8:52 am git commit 45a0e6eb20
I've attempted to test this on the last couple of weekly builds, but the resulting 3MF file is not able to be read by PrusaSlicer or Fusion 360 (the only two programs I tried).
OS: macOS 10.16
Version: 0.20.29126 (Git)
Hash: 6c1c63cffebe6a9d55bd9b1d8ca6b741a4d16548
Python 3.10.4, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
I've attached my simple FreeCAD PartDesign model, as well as the 3MF output (which I had to Zip, as the forum software won't let me choose the 3MF file type to upload).
Thanks!
John
Narrow Hose Adapter-3MF-Test.3mf.zip
(83.78 KiB) Downloaded 19 times
Narrow Hose Adapter-v4.FCStd
(29.09 KiB) Downloaded 13 times
Re: .3mf file type
JohnOCFII wrote: Mon Jun 13, 2022 3:20 am I've attempted to test this on the last couple of weekly builds, but the resulting 3MF file is not able to be read by PrusaSlicer or Fusion 360 (the only two programs I tried).
As reference I have used Blender and that imported the file that was created with FreeCAD without problems. Do you get any error messages?
Does PrusaSlicer or Fusion 360 support the export of the 3mf format? If yes you could export the object from FreeCAD in a mesh format that the two programs support (e.g. STL), import into PrusaSlicer or Fusion 360 and export as 3mf. This way the output files can be compared.
jeno
Re: .3mf file type
Post by jeno »
JohnOCFII wrote: Mon Jun 13, 2022 3:20 am ...
Would you mind trying the attached with Prusa Slicer and/or Fusion 360?
cheers
AdapterBody.zip
(950.16 KiB) Downloaded 13 times
drmacro
Re: .3mf file type
Post by drmacro »
A trick I've used with great success recently is using a combination of FCStd and Blender with sverchok Read/Write nodes.
For example, Blender under linux has no free step addon. So read the step in FreeCAD, read the FCStd with sverchok nodes.
It works the other way when Blender can read the file type as well.
