.3mf file type
Antares
.3mf file type
Post by Antares »
Hello people
I ask about .3mf file type for Freecad, because a lot of resin printer slicers support it. It seem is really light than .stl and has more information, and no need triangles to pass information.
There exist some project to including it in the list of type of files than FreeCAD can export?
People maker, like me, will be thankful
Thanks you
Jordi.
PD: We can export files to .stl, but if we import .stl files is not possible to edit or modify
Thanks you
Jordi.
TheMarkster
Re: .3mf file type
Post by TheMarkster »
I haven't tried it, but there is an online converter (supposedly free) that can take step files and convert them to 3mf
https://3d-convert.com/en/convert/stp-to-3mf.html
Re: .3mf file type
Here are the (simplified) specs of the file format: https://en.wikipedia.org/wiki/3D_Manufacturing_Format
So, to support meshes this shouldn't be very complicated to implement our own exporter (and maybe importer).
The complete specs can be found here: https://3mf.io/specification/
Re: .3mf file type
git commit e3ebe4bc9f supports basic 3MF export.
charlottmia19
Re: .3mf file type
Post by charlottmia19 »
Solution #1: MakePrintable Press “Upload Files” and choose your 3MF file. Select “Quick Repair”. This may take several minutes. Click on “Save/Export”. Choose “3D model” and then STL. Press “Download”, and your file should start downloading to your computer.
Online website all3dp.com
JohnOCFII
Re: .3mf file type
Post by JohnOCFII »
wmayer wrote: Fri Oct 22, 2021 3:12 pm git commit e3ebe4bc9f supports basic 3MF export.
Is this 3MF export supported only in the Mesh workbench?
I've been starting to use 3MF more often, in place of exporting as STL for 3D printing. When choosing File --> Export for a part primarily designed in PartDesign, I'm not seeing 3MF as an option in the dropdown.
Thanks,
John
OS: macOS 10.16
Version: 0.20.28909 (Git)
Hash: 6beef68ae1
Locale: C/Default (C)
DS2FineFilter-Frame.FCStd
(48.83 KiB) Downloaded 74 times
Re: .3mf file type
JohnOCFII wrote: Wed May 25, 2022 7:58 pm I've been starting to use 3MF more often, in place of exporting as STL for 3D printing. When choosing File --> Export for a part primarily designed in PartDesign, I'm not seeing 3MF as an option in the dropdown.
Currently it's only accessible in the Mesh wb's own export function. But sure I can add it to the global export dialog, too.
Re: .3mf file type
JohnOCFII
Re: .3mf file type
Post by JohnOCFII »
wmayer wrote: Thu May 26, 2022 8:52 am git commit 45a0e6eb20
Thanks!
Re: .3mf file type
Is it available for import too?
