[Testing] Decimal separator substitution
Re: [Testing] Decimal separator substitution
Hi
Version: 0.20.26375 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
mario
Qt version: 5.12.9
OCC version: 7.5.3
mario
Hi
if i work with a point the value change
si je met un . (point) la valeur change et la grandeur aussi ,
10 mm deviennent 100 mètres
et 1 mm devient 10 mètres
mario
mario
I already explained this behavior in a previous post of this thread. I also told it has nothing to do with the PR (directly). Just if you enable the decimal point substitution (this PR) you'll be less prone to get this behavior if you used to enter numbers with numerical pad.
Hi
mario
Ok done'General/SubstituteDecimalSeparator
mario
Sure, but I cannot test the new feature. I requested an UI option in the preferences but cannot find this. I insist on an UI option because this topic pops up frequently so apparently it is important for users so we should offer the option the normal way.
You may be right, but insisting seems a bit harsh for something that didn't exist at all before. There were not really many descussions about this topic in this forum.
Sorry, can't remember this request. Anyway my plan was and still is that the feature is a bit tested by super users before being official. Hence my previous post.
I proposed this first here: https://forum.freecadweb.org/viewtopic. ... 20#p544241 and then also later in Github or another forum post.
I wrote "insist" to push this . As I wrote, this topic occurs in the forum frequently and since you already implemented it, there is no need to hide it. It is relevant for some users thus a UI entry for the setting is worth it. Since we are still in normal development mode for FC 0.20, we have enough time to be tested.
OK. What you wrote there is a bit different as you want that thousand separator is interpreted as decimal separator when possible.uwestoehr wrote: ↑Mon Nov 22, 2021 5:40 pm I proposed this first here: https://forum.freecadweb.org/viewtopic. ... 20#p544241 and then also later in Github or another forum post.
This isn't what is provided in this PR, and would require some other modifications especially in formula/expression parsers, which may not be a small effort.
Anyway I can provide an UI option for this PR, just have to find the right spot. I wonder if at a time it could be a good thing to create a "Advanced" preference page where we can push basically everything stored in Fine-tuning without caring much about user-friendliness.
