[FIXED] Ticket #4610: OCC's step export pathway generates bad geometry
Discussion thread for issue #4610: OCC's step export pathway generates bad geometry
Reason: Ticket fixed (and included in upstream OCC 7.5.2)
greyltc
Re: Ticket #4610: OCC's step export pathway generates bad geometry
Post by greyltc »
Thank you for starting a thread for this.
I don't exactly know whose code this is a bug in, but I suspect it's in opencascade's.
I've filed a report there too: https://tracker.dev.opencascade.org/view.php?id=32264
I've seen a similar issue with other software (cadquery) that uses occt's step export feature and filed a bug there too!
https://github.com/CadQuery/cadquery/issues/697
Re: [FIXED] Ticket #4610: OCC's step export pathway generates bad geometry
Fix is included in upstream OCCT 7.5.2 (check ticket for details)
vern.zimm
Post by vern.zimm »
What version of FreeCAD is available with OCC 7.5.2? Weekly builds up to 0.20.24847 are still using 7.5.1, and the newest 0.19.2 release is using 7.4.0?
vern.zimm
Post by vern.zimm »
As of (at least) 0.20.24910 the OCC version is 7.5.2.
I tested on a few problem parts, and everything seems to be working correctly, thanks!
