So F4 just swaps back and forth between state 2 and 4, or 2 and 3.
Can you describe the problem in more detail? I've read the posts you linked, but I didn't understand what the issue was.
that explanation helps, thank you.
I strongly suggest against using F4 / switching all panels at the same time. That shuffles around the interface a lot, enables some disabled panels as well. I would strongly recommend using the individual buttons on each of the docksbambuko wrote: ↑Tue Jan 18, 2022 1:47 pmthat explanation helps, thank you.
When I use F4 in regular FreeCAD it toggles between 1 and 2 and then back to 1 (if you so desire)
When trying it on a version with Vertical UI, not only were there 4 states (which you just explained, thank you) each state leaving more and more "jumbled". but there was no way back to state 1, regardless of however many times I press F4.
I will come back with more illustrations and explanations.
I now have totally separate installation of FreeCAD to experiment with (leaving working version safe and conservative),
so even if I mess it up it's no big deal
Yep
I think you're attributing too much to VertUI. It's really not that smart.
shame because I like it
Having spent a fair bit of time playing with it today I now understand it more and agree with you - I was confusing things (as usual )
