Ticket #4508 - Grouping problem (object disappearing after drag drop into group)
If group and object has same prefix, then when putting object into this group, or pulling out, object may dissapear
After close / open project, dissapeared object will be on place before grouping operation, even if project was saved after object disappearing.
This affect all type of objects, but only when group name and object name has same prefix.
Example in attachement. Try to pull out or drop into group.
OS: Ubuntu 18.04.4 LTS (Unity:Unity7:ubuntu/unity)
Version: 0.19.
Branch: unknown
Hash: 1f0b7793e6e48c18e818f17b082790a4af0124d6
Python version: 3.6.9
Qt version: 5.9.5
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
- grouping_bug.FCStd
- (3.92 KiB) Downloaded 48 times
Re: BUG : Grouping problem (object disappearing)
Problem still exist when object has same name start.
When drag-drop into group, object may disappear.
Try to drag-drop V2040 into group "Profile"
- grouping_problem.FCStd
- (19.54 KiB) Downloaded 48 times
Sorry, cant reproduce. Could you try to make a video showing the issue?
OS: Windows 8.1 (6.3)
Version: 0.19.23076 (Git)
Hash: d5f6c096b8089d5835a22a80667b00eda6721526
Python version: 3.6.8
Qt version: 5.12.1
Locale: Bulgarian/Bulgaria (bg_BG)
Qt version: 5.12.1
Here is it
https://gofile.io/d/TmLcLz
It happens not always, but often. Try to drop in / drop out in case if not happens after first attempt.
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
Can you still recreate on latest master?HardRock wrote: ↑Wed Dec 09, 2020 7:43 pm Still present
Now I have submitted a bug in tracker
https://tracker.freecadweb.org/view.php?id=4508
I can't recreate on
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.24054 (Git) AppImage
Hash: ed873038025277f220dfaa058599a0dfbb435835
Python version: 3.8.6
Re: Ticket #4508 - Grouping problem (object disappearing after drag drop into group)
The linked video doesn't exist anymore.
I cannot reproduce from your description. Perhaps you encountered the following issue, which seems to be non deterministic, but it isn't:
If you drop the file on the group it is moved into the group. If you move it on a file inside of the group, then the files are exchanged. This seems to be independent from the names of the objects.
Hello all.
Stiil present in latest version.
Here is a new video file
https://gofile.io/d/zL8ZUN
Problem appears not always, but frequently.
Version: 0.19.
Branch: unknown
Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a
Qt version: 5.9.5
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
No issue here.
OS: Ubuntu 20.04.2 LTS (XFCE/ubuntustudio)
Version: 0.19.24171
Hash: 13ed4bc6e8ec9be74be792f569a61b4affa49656
Python version: 3.8.5
Qt version: 5.12.8
Version: 0.19.24171
Qt version: 5.12.8
I can see the video but can't confirm the bug.HardRock wrote: ↑Sun Feb 21, 2021 3:39 pm Stiil present in latest version.
