Call for screenshots
- ifohancroft
Re: Call for screenshots
Here's one from me:
I like making, breaking and modding stuff, using a soldering iron, code or both. https://ifohancroft.com
Quick Tip: You can increase the resolution of the STL file by changing the "Deviation" property of the model in the View Tab of the property editor (usually that's the panel on the bottom left).dcapeletti wrote: ↑Sun Dec 16, 2018 12:34 pm But now look at this animation that I made in blender with the stl produced in FreeCAD.
Greetings
Two part aluminum rim construction in FreeCAD I did a long time ago.
This is a Keyshot render of the exportet STEP Files.
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
Nice job you did there!OPEN CASCADE wrote: ↑Wed Mar 15, 2017 10:07 am As you can see from this thread, you can use CADRays for creating photo-realistic screenshots:
I am attempting to utilise my "free" time during the lock down getting through some of the old files I have been meaning to fix the last 10 years or so.
One of the main things was to get the files all sorted and get some of them converted from formats I no longer have access to as well.In some cases I find it's just better for me to take the 2D .pdf files I have and remake the model from scratch.
I'm pretty happy with my current setup:
OS: Pop!_OS 20.04 LTS (pop:GNOME/pop)
Version: 0.19.21125 (Git) AppImage
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Python version: 3.8.2
OS: Pop!_OS 20.04 LTS x86_64
Kernel: 5.4.0-7634-generic
CPU: AMD Ryzen 9 3900X (24) @ 4.000GH
GPU: AMD ATI Radeon RX 470/480/570/57
Memory: 4538MiB / 15991MiB
I will be happier when I can get back to the Daily branch but it's all good for now.
- New wheel design
- Screenshot from 2020-06-06 20-02-00.png (518.85 KiB) Viewed 22983 times
- Recreated hydraulic cylinder
- Screenshot from 2020-05-28 15-53-49.png (466.64 KiB) Viewed 22983 times
Nice!
- OficineRobotica
Beutifull.....also the ultrawide is nice
Check out my Youtube channel at: https://www.youtube.com/@OficineRobotica
Made just for fun...
Seems like you had a LOT of fun
Would you mind telling a bit about the modeling? Workbench used, double mirrors, limits you encountered, problems to be solved, ...
