[Issue #6189] Surface to surface tangency
Re: Surface to surface tangency
Pauvres_honteux wrote: Sun Sep 27, 2020 9:25 am As of this moment in time, the latest AppImage reads 0.19.22492.
0.19.22518
And under what function/clickable icon did you put it?
I don't have an icon so far. That's why you must start it from the menu.
Would someone volunteer to write some clear instructions on how to use this feature?
freecad-heini-1
Post by freecad-heini-1 »
wmayer wrote: Sun Sep 27, 2020 10:10 am
0.19.22518
I've been reading along here for quite a while now and find the efforts very good. I offer myself as beta tester.
@Werner, please explain in a short example how I create a new surface between two surfaces which is tangential to the two original surfaces. As soon as I have understood how to do this, I will publish it in the German Forum.
Thank you very much and best regards
Wilfried
wmayer wrote: Sun Sep 27, 2020 10:10 am I don't have an icon so far. That's why you must start it from the menu.
Shall I x-post to the UI/UX subforum for help on this ?
vocx
Post by vocx »
wmayer wrote: Sat Sep 26, 2020 4:20 pm With this code snippet you can create the section curves as in the example:
I'm testing this.
Can this new object use as input a wire? Or should it be an individual edge only? That means it would only be usable with curved edges, like B-splines.
Only edges can be used. The actual algorithm is GeomFill_NSections that requires a list of curves. The curves are obtained from the selected edges.
freecad-heini-1 wrote: Sun Sep 27, 2020 3:54 pm I've been reading along here for quite a while now and find the efforts very good. I offer myself as beta tester.
Wilfried
Don't you remember that you've already used it and even made a video about it?
jmaustpc
Post by jmaustpc »
Would one of these be adequate? Roughly based on your code for the demo edges a few posts back and being consistent with the other Surface icons.
Surface_Sections1.svg
(10.14 KiB) Downloaded 58 times
which at 2 different resolutions looks like this
Or
Surface_Sections2.svg
(9.64 KiB) Downloaded 43 times
Jim
Thanks! They are great!
EDIT:
git commit a4176fa15
