FreeCAD Conda Distribution
Re: FreeCAD Conda Distribution
adrianinsaval wrote: ...
conda update -n fcenv-dev freecad
did not update to 0.21 yet.
Following the link you gave me show that packages are build and even in:
https://anaconda.org/freecad/freecad/files
It seems that are present.
Is there some other action to do to update?
TIA and Regards.
what version of python is your env using? I only see versions for 3.9 and 3.10 on that page, perhaps you are on a 3.8 environment? not sure how that works
looo
Post by looo »
onekk wrote: Wed Jun 22, 2022 1:27 pm
adrianinsaval wrote: Wed Jun 22, 2022 1:21 pm patience young padawan ...
:D
Sorry I haven't noted the time of the commit!
Will be 0.20 downloadable as stable? so:
conda create --name fcenv --channel conda-forge freecad
Will install 0.20 ?
TIA and Regards
0.20 is in conda-folge. So if you want the stable version install it without the freecad/label/dev channel. Normally 0.21-pre builds should be the preferred ones if you do not mention a version. In case you have any problems it's also possible to mention the version like `conda install freecad=0.21`.
it's possible that the stable 0.20 version uses some newer deps and therefore is preferred. I guess this will be resolved in the near future.
looo wrote: Fri Jun 24, 2022 9:44 am 0.20 is in conda-folge. So if you want the stable version install it without the freecad/label/dev channel. Normally 0.21-pre builds should be the preferred ones if you do not mention a version. In case you have any problems it's also possible to mention the version like `conda install freecad=0.21`.
Thanks, for answering.
OK for 0.20 so the stable ion conda-force now is 0.20
for 0.21 I have set the fcdev-env and at least yesterday it will not update freecad to 0.21 leaving the 0.20 installed.
Ok to force version, but I have a couple of question.
I usually update the fcdev-env with:
as said above.
1) If I force the update to 0.21 using the line you kindly supllied me, subsequent updates will refer to 0.21?
2) I have read conda documentation, but I was lost, in particular, "packages recipes" (I don't know if term is correct) in other word what you have modified in the github repo that @adrianinsaval linked (that should be your github repo) are update and taken in account by my conda install with line above or I have to do some other actions?
TIA and Regards
looo
Post by looo »
as I said in the previous post it's possible that the stable version is using some newer versions. I guess updating the 0.21 feedstock (rendering) should fix this. Lets try it:
https://github.com/looooo/freecad-feeds ... 71307960b9
For now you need to force the 0.21 version. I guess this is also possible with the update command: `conda update --all freecad=0.21`
looo wrote: Fri Jun 24, 2022 10:01 am
Not so very plain transition:
conda install -n fcenv-dev freecad=0.21
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: done
Probably I have to use some flag, but at least it has been installed.
I have to study more miniconda.
Thanks again for your help
looo
Post by looo »
onekk wrote: Fri Jun 24, 2022 10:23 am
you can also try to use mamba which is a better dependency solver replacement for conda...
Btw.: I guess I found the reason why the environment wasn't updated automatically to 0.21:
https://github.com/looooo/freecad-feeds ... 085bd4b6b9
looo wrote: Fri Jun 24, 2022 10:32 am you can also try to use mamba which is a better dependency solver replacement for conda...
Thanks, I will see how to install it on my miniconda install.
looo wrote: Fri Jun 24, 2022 10:32 am Btw.: I guess I found the reason why the environment wasn't updated automatically to 0.21:
isn't tbb needed for multithreading in occt?
looo
Post by looo »
adrianinsaval wrote: Fri Jun 24, 2022 11:19 pm
It's optional. https://github.com/conda-forge/occt-fee ... -981799139
