Ticket #4186: hang on union of objects
Discussion thread for issue #4186: hang on union of objects
Re: Ticket #4186: hang on union of objects
I can reproduce by
loading the file
switching to Part WB
Highlighting 'array' and 'cut' in the tree
Running Part_Union
Result: FC just hangs. Also I can't exit the operation.
Starting FC from the terminal shows no errors or output that indicates FC is having issues.
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.23237 (Git)
Hash: 71726a11d0844f263dad636fb98bb996a479e007
Python version: 3.8.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
loading the file
Running Part_Union
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Those are 1600 unfused overlapping cylinders... Cut with a half sphere... What is a reasonable timeframe for that? If I set Number polar to 4 (16 copies) everything works as expected.
lol, good point. Nevertheless, it would be nice to know what's going on though and to be able to cancel the operation.
1.1 GB of RAM and 1 core at 100%. Looks like OCC has control now and unless there is some mechanism there to check the outer world from time to time I don't see how can that be monitored/canceled.
I will wait to see if and when will that finish.
Is it still running??
Nah, 13h were enough. Since there was no notable change in used memory I had no way to distinguish if something was happening or it was stuck in some infinite loop. I thought to make an experiment and increase copies, record times for recalculation and make a prediction for the expected time but did not... yet
13h ?!? Jeebuz!kisolre wrote: ↑Fri Dec 11, 2020 1:17 pm Nah, 13h were enough. Since there was no notable change in used memory I had no way to distinguish if something was happening or it was stuck in some infinite loop. I thought to make an experiment and increase copies, record times for recalculation and make a prediction for the expected time but did not... yet![]()
To you knoweldge, are there other OCC commands that FC monitors for this type of response and offers another solution for this type of behavior?
My knowledge is quite limited here
FreeCAD has such mechanism to cancel the recompute, which I assume works between OCCT operation. Shouldn't there be also such mechanism in OCCT?
The union would be invalid anyway, so I started with setting Fuse=true, alas, with a similar result. I forgot the running process, until my browser told me to close, because the system was running out of memory.
However, from what I see, this is not a bug, the task is simply too complex to be finished within a reasonable time and space frame.
So I would either close change the ticket to a feature request: "Implement a possibility to cancel long running tasks".
Perhaps such ticket exists already, at least it was discussed before.
