Hello everyone,
In step exporter of FreeCAD 0.18, if we are exporting two objects into a step file and on opening this generated step file, FreeCAD shows two objects having the same label name which is before exporting. But step exporter of FreeCAD 0.19 behaves differently. For eg, if we exporting two objects into a step file and on opening generated step file, FreeCAD shows only single object which is the compound of two objects and all information of label name of objects is lost.
Can anybody help me how to export multiple objects to a step file so that objects cannot merge and name of objects in step file should be exactly same as a label as in the FreeCAD document?
Thanks in advance!
Step exporter of FreeCAD 0.19 merging objects into single object
Re: Step exporter of FreeCAD 0.19 merging objects into single object
Please retry with 0.19, there were some changes made.
I already using the latest available build of FreeCAD 0.19.
OS: macOS 10.15
Version: 0.19.19274 (Git)
Hash: 1da11e4e5c760e0db7b8e0d9a80ca5a8c172b326
Python version: 3.8.1
Locale: English/India (en_IN)
Found solution.
Using GUI: Untick the "Enable STEP compound merge" button in STEP exporter preferences (Open FreeCAD preferences -> Import-Export tab -> STEP tab -> See options under Import section)
Using Python console:
FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Import/hSTEP").SetBool("ReadShapeCompoundMode", False)
Thanks,
@amrit3701 I'm trying to do this with Python so I don't have to edit my preferences, because I'm working on server code that doesn't use a GUI. Is there a typo on the Python command (e.g. "hSTEP" instead of "STEP")? It doesn't seem to make a difference either way.amrit3701 wrote: ↑Thu Jan 23, 2020 5:49 pmFound solution.
Thanks,
I'm running this in "normal system Python" rather than FreeCAD's console, but I don't think that's the problem, because every other FreeCAD instruction works fine.
Are you aware that this topic is rather old and that it's based on 0.19?
