Ticket #3420 - SVG imports from inkscape lead to wrong dimensions
issue #3420 - SVG imports from inkscape lead to wrong dimensions
Bug was first isolated thanks to the german FreeCAD contingent ;) in https://forum.freecadweb.org/viewtopic.php?f=13&t=27344
With the change from 0.91 to 0.92 inkscape devs changed the conversion factor of userunit (uu) and mm. Pre-0.92 it was 1uu=1 inch/90 and starting from 0.92 it is 1 uu=1inch/96. This was necessary to meet the actual recommendations/rules of svg-standard and css. See article in inkscapewiki for further reading.
When a user creates a file in inkscape with absolute dimensions (mm) and saves it, then imports it into FC, bodies in Freecad come out with too large dimensions. For example - a 100mm square will be 106,66mm in FC now (100 x 96/90).
Example SVGs are available in the ticket
Re: Ticket #3420 - SVG imports from inkscape lead to wrong dimensions
Will there be a need to make an import pop-up asking if the user wants pre-Inkscape0.92 or post-Inkscape0.92 compatibility?
PrzemoF
Post by PrzemoF »
Maybe we could use the version stored in the actual SVG file?
inkscape:version="0.92.4 (5da689c313, 2019-01-14)"
Kunda1 wrote: Fri Jun 28, 2019 10:41 am Will there be a need to make an import pop-up asking if the user wants pre-Inkscape0.92 or post-Inkscape0.92 compatibility?
No, I don't think so. It is all going to the newer versions, in FreeCAD as well as in Inkscape. When 0.19 becomes stable even more people use newer inkscapes, probably 1.0.
PrzemoF wrote: Fri Jun 28, 2019 12:57 pm Maybe we could use the version stored in the actual SVG file?
Hey @PrzemoF, would you mind elaborating how that could be useful?
PrzemoF
Post by PrzemoF »
I hope I don't miss something obvious :D
- in inkscape up to Pre-0.92 it was 1 uu=1 inch/90
- in inkscape starting from 0.92 it is 1 uu=1 inch/96
- SVG file created by inkscape contains a line like this:
So by checking the version of inkscape that saved the actual SVG file you can tell what should the conversion factor.
openBrain
Post by openBrain »
Given that the second (96 DPI) should be the standard. :P
Actually maybe a better algorithm is "SVG is 96 DPI except for Inkscape < 0.92 where it's 90 DPI". ;)
Hope this is the current behavior. :)
Hey @wandererfan, could you weigh in on this? How are we evaluating SVG's currently ?
wandererfan
Post by wandererfan »
Kunda1 wrote: Thu Jul 04, 2019 10:45 pm Hey @wandererfan, could you weigh in on this? How are we evaluating SVG's currently ?
Geometry imports are done by Draft.importSVG.py and it has 90 ppi hard coded in a number of places.
Drawing and TD don't seem to consider ppi at all, just user units.
Looks like it's in the getsize() function: https://github.com/FreeCAD/FreeCAD/blob ... VG.py#L263
