node editor - pyflow
Re: node editor - pyflow
yes please, re-take the project because probably @microelly2 had COVID.
are you serious or joking?jtm2020hyo wrote: ↑Fri Jan 29, 2021 10:32 am yes please, re-take the project because probably @microelly2 had COVID.
I just discovered this project...doing some research and WOW...Any news on their condition? I apologize in advance for not looking at other threads about it but it also seemed like it might be good to have an update here in the work thread to help future me.
...just was a hypothesis, sorry.
PyFlow WB is already usable but I found some bugs.mwilding wrote: ↑Mon Feb 15, 2021 11:42 pm
Was not appropriate.
Hi !
I'm currently working on another graphical programming system (see Graphical scripting : FreeCAD/PureData connection).
PyFlow implements an exec signal to activate nodes along a chain when Pure-Data has a hot-input concept i.e. one object inlet is used to set a parameter AND activate the object.
The exec chain can be implemented at least for objects I create but I'd like to have your opinion about the two possibilities.
look cool, could share a sample designing a Stair? I found problems trying to do this but looks like your nodes can solve them.flachyjoe wrote: ↑Thu Mar 11, 2021 8:19 pm Hi !
here a sample:
the inspiration:
.... the problem I found was that is not possible to create such a landing, at least not like I was trying.
... could help us here?
another sample here:
according to the video PyFLow could solve this and maybe you new node editor.
- 2D stair face.FCStd
- (25.84 KiB) Downloaded 64 times
Yes sure, such stair need tapered treads. http://lionel.ponnelle.pagesperso-orang ... cement.htmjtm2020hyo wrote: ↑Thu Mar 11, 2021 8:32 pm the problem I found was that is not possible to create such a landing, at least not like I was trying.
I can't see where nodes are needed…
In each version appears more bugs related to PyFlow, in 0.19.1, maybe is need to change the method to connect FreeCAD with PyFLow, maybe like Pure-Data external installation.
... this because, In windows, installing PyFlow directly in the Python 3.8 library do nothing but in Python 3.9 library works correctly, maybe Mr. Microelly was setting the stage to use PyFlow with Python 3.9?
... also in the previous versions, PyFlow and their nodes load (except Maya because python 2) but always appears bugs or errors.
...any suggestions about how can we link directly the PyFlow.exe created in Windows to FreeCAD instead create a git package?
not sure but looks like PyFlow OpenCV nodes have not to support for python 3.9
PyFlow for FreeCAD was abandoned?
