node editor - pyflow
microelly2
Re: node editor - pyflow
Post by microelly2 »
Two nodes to find best fitting cylinders or sphers for a given surface
phpBB [video]
see too:
https://youtu.be/Ahdjfrpk2lA
https://youtu.be/Mz1CSYTJw6w
microelly2
Find a curve with these constraints:
start and endpoint
tangent direction at start and endpoint
curvature at start and endpoint
result is a 6 poles bspline degree 3.
phpBB [video]
HakanSeven12
Post by HakanSeven12 »
Is there a node for delaunay triangulation?
microelly2
HakanSeven12 wrote: Tue May 19, 2020 6:37 pm Is there a node for delaunay triangulation?
https://youtu.be/fV-Y8beWCpQ
HakanSeven12
microelly2 wrote: Wed May 20, 2020 4:44 am
Good :) thanks
microelly2
approximate a curve by a simple bezier curve (4 Poles) with tangent constraints at the endings.
phpBB [video]
FreeCutter
Post by FreeCutter »
This is very, very interesting for me and first of all thanks a lot to microelly2 developing all this and the nice examples/use cases!
I would like to ask about this one:
microelly2 wrote: Wed May 13, 2020 3:41 pm BSpline Surfaces are not developable.
To get a paper model of a terrain I split the surface in stripes, convert them to ruled surfaces and approximate the result by a chain of trinagles.
The result can be printed out, cutted and composed to a 3D paper model.
The last steps can be done by children too.
Currently I'm working 'manually' with the work flow shown below (steps 1. to 7.) - and unfortunately this is not FreeCAD rather than SketchUp. Background is the idea of making a shell for a trike bicycle (https://forum.freecadweb.org/viewtopic.php?t=40991) but much more curvy than this one (https://forum.freecadweb.org/viewtopic. ... 49#p351249).
It would be very helpful to do this parameter based as it would give much more and easier control in case of variation.
Would it be possible to have control about the "unfolded" width and height of each triangulated quad by the node editor pyflow?
Thanks for your ideas and support!
Overview Workflow.jpg (66.58 KiB) Viewed 4025 times
FreeCutter
Visit my GitHub profile
microelly2
FreeCutter wrote: Thu May 21, 2020 4:59 pm It would be very helpful to do this parameter based as it would give much more and easier control in case of variation.
Yes we can. This is the construction of an offset cell.
I can combine my method with this idea to get such 3d cells: https://youtu.be/-DsEbBIA5-E
thank you for yor example workflow. This kind of cells will make the paper model more stable
FreeCutter
Thanks a lot - I started to install according to https://github.com/microelly2/NodeEditor and ... got stuck. :?
So this is my FreeCAD version:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: ee440bea612721e51b5af4c621ce15b1885a6bc0
Python version: 3.6.9
Qt version: 5.9.5
After running the git commands I got init messages in the 'Report view' after starting FreeCAD:
Init:      Initializing /home/mapa/.FreeCAD/Mod/Qt.py(InitGui.py not found)... ignore
Init:      Initializing /home/mapa/.FreeCAD/Mod/PyFlow(InitGui.py not found)... ignore
Init:      Initializing /home/mapa/.FreeCAD/Mod/NodeEditor... failed
  File "<string>", line 125, in InitApplications
  File "<string>", line 43, in <module>
ModuleNotFoundError: No module named 'blinker'
During initialization the error "No module named 'blinker'" occurred in /home/mapa/.FreeCAD/Mod/NodeEditor/InitGui.py
Please look into the log file for further information
Thus, installed 'binker' by 'pip install blinker' - but during this I got the error 'Failed building wheel for blinker'. However, final message was 'Successfully installed blinker-1.4'. Well, I'm not sure if this is really true.
Restarting FreeCAD still gives the above stated error message about 'No module named 'blinker''.
May you could please help me how to proceed?
FreeCutter
Syres
Post by Syres »
Could it be as simple as:
pip install wheel
Not sure whether you would then have to run:
pip install --upgrade blinker
