Feature request thin element for Part and PartDesign workbench
Re: Feature request thin element for Part and PartDesign workbench
jonasb wrote: Sat Jan 15, 2022 1:53 pm Such a hypothetical "Thickness2D" could be similar to Part Offset2D, but producing not only one offset, but two: one on each side of the referenced lines.
Yes and No, it depends, on whta you are trying to do.
Usually using offset you are otaining different shapes as offset tend to make things using some math behind that make
This code:
def wire_shape():
    pol_r = (
        (000.0, 00.0, 0.0),
        (135.0, 00.0, 0.0),
        (135.0, 48.4, 0.0),
        (131.0, 54.3, 0.0),
        (105.1, 56.6, 0.0),
        (070.0, 58.5, 0.0),
        (053.3, 59.4, 0.0),
        (025.8, 82.0, 0.0),
        (002.8, 82.0, 0.0),
        (000.0, 67.2, 0.0),
        (000.0, 00.0, 0.0)
    rim_profile = Part.makePolygon(pol_r)
    # Part.show(rim_profile, "rim_profile")
    return rim_profile
obj = wire_shape()
Part.show(obj, "original_wire")
o_off = 1.5
obj1 = obj.makeOffset2D(o_off * -1)
Part.show(obj1, "neg_off_wire")
obj2 = obj.makeOffset2D(o_off)
Will result in this shape (one corner shown):
maybe this is what you want, maybe not.
Using GUI Offset2D could use a different strategy to offset corners, when I've used it on my "original_wire" polygon, using mode=Pipe, join=Tangent.
I obtain:
At least in FreeCAD 0.20, Libs: 0.20R26720 (Git).
What is correct, for me GUI way is more correct, but makeOffset2D method is more coherent from what I was used in other CAD/CAM as on a corner the "correct" constant distance is a radius, like when cutting with a cnc.
This pose a question? How to achieve this behaviour with Scripting?
Sorry for some OT parts.
freecad-heini-1
Post by freecad-heini-1 »
freecad-heini-1 wrote: Sat Jan 15, 2022 7:34 am
wmayer wrote: Sun May 03, 2020 9:19 am issue #0004334
Friendly reminder of this feature request
"thicken a sketch". Thank you
Is there anything new about this yet?
FBXL5
Post by FBXL5 »
I'd like to have such a tool in PartDesign, too. I still use SheetMetal_AddBase as a workaround, as long as I can live with its automatically inserted radii.
kadet
Post by kadet »
I've created new issue: https://github.com/FreeCAD/FreeCAD/issues/10538 in the comment is my initial idea for how this feature could be implemented, based on simple experiments with API and FreeCAD. Feel free to share your thoughts.
Side note: Technically there already is imported issue based on #0004334: https://github.com/FreeCAD/FreeCAD/issues/6057, but it's old, has no real description and because of that is neither informational or discoverable. Personally I'd suggest to close it as duplicate of mine which should be more discoverable.
