Exported SVG's incompatible with svgnest
Witz
Post by Witz »
I'm trying to export SVG's of parts for nesting and CNC cutting of parts for Open Source Ecology. I tried the drawing workbench first, but then I saw a thread recommending using 2DView in the Draft WB. The 2DView produces cleaner-looking SVG's, but still, has flaws. Exports I've tried are missing holes or have inf fill color in some holes. The main issue though is when I upload to svgnest I can not select the bin as a component; All the parts have independent line segments not continuous. Maybe this is more of an Inkscape question if there is a step I can do to fix it in there, but the inconsistency in the SVG export files makes me think FreeCAD export methods is buggy.
I made a video showing some examples here: https://youtu.be/uHi3vLb_nOU
There are also recent notes on my log at OSE: http://opensourceecology.org/wiki/AbeAnd_Log
Thanks for any assistance on this.
--Abe
OS: Ubuntu 16.04.3 LTS
Version: 0.16.6712 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: da2d364457257a7a8c6fb2137cea12c45becd71a
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.8.0.oce-0.17
Re: Exported SVG's incompatible with svgnest
Offtopic: why doesn't OSE adopt 0.17 in to it's workflow yet ?
saso
Post by saso »
In the following topic I have explained how to clean up in Inkscape the exported svg from FreeCAD and make it work with svgnest.
https://forum.freecadweb.org/viewtopic.php?f=3&t=14038
Note that FreeCAD 0.17 has built in support for the complete workflow for this...
https://forum.freecadweb.org/viewtopic.php?t=19245
https://forum.freecadweb.org/viewtopic.php?t=23484
Witz
Post by Witz »
Actually, 0.17 and 0.16 are included in OSE Linux, but I need to install 0.17 on my desktop. I may be a holdout since I have been assuming it is more beta still. I will install 0.17 and retry the workflow. I saw the thread explaining 2DView, but didn't realize I needed 0.17 ? I see yoriks new nesting solution to, but I assume it is to beta for the part complexity.
Also, I did try uploading gh.svg from that thread to svgnest yesterday and it looks wrong like it has issues with the arcs so maybe svgnest has been updated since then.
Once I get all this working I plan to make an instructional video showing from FreeCAD parts to G-Code for the CNC torch table.
It will be nice when the code gets improved enough maybe we will be able to select parts, enter counts and get G-code out with a few clicks.
Thanks for the info.
saso
Post by saso »
This post https://forum.freecadweb.org/viewtopic. ... 20#p112312 and some after it are the important ones for the Inkscape workflow...
Witz
Post by Witz »
I installed FreeCAD daily and have been testing various export methods. With 0.17 the only issue appears to be that circles are polygons with fewer sides relative to size. Exporting to DXF then saving as SVG in Inkscape looks better, but the part objects don't appear to convert to paths so it is not compatible with that workflow. Attempts to load the converted SVG's into SVGNest also failed. Once I was able to select what I though was the bin I set, but it was a part because the scaling was off and it separated the parts and nested the cut holes. Then I had more trouble with it only selecting line segments despite having selected and joined the nodes for the bin.
I tested with 0.17 update today and the previous version.
Version: 0.17.12396 (Git)
Build type: None
Hash: fb2b9d6cef287d826a905b90928d41a03e38d928
Qt version: 4.8.7
OCC version: 7.1.0
Have you tried the FreeCAD builtin support as mentioned by saso? How is it working?
