No, your comment in the above PR is sufficient.
Freecad 0.17 - Pad up to face - Datum Plane is invalid
Re: Freecad 0.17 - Pad up to face - Datum Plane is invalid
@NortmandC thanks for checking out my example.
Shall I/can I raise an issue for this?
This is just because I quickly placed the repeated pattern in the sketch with a mouse and didn't check the constraint it generated. I don't think it should cause this issue..?
Sorry, I forgot this topic.
I am unable to reproduce your issue with a file made from scratch.
Can you reproduce it with a new file? If you can't, I'd hold off creating a report. Maybe there's something else in your file.
No, but it is poor constraining.
Hello again,
Ok, here are some clean examples:
"00 pad from datum plane to xyplane with single sketch item does not work" => the pad exists but continues through the xy plane (I think this is an issue)
"01 pad from xyplane to datum plane with single sketch item works" => this is ok
"02 pad from xyplane to datum plane with two sketch items does not work" => if a second sketch item is added to example 01, it does not appear in the pad. If you try to change this to a dimension based pad, a message says "Pad: Result has multiple solids. This is not supported." (I think this should have the same alert for the up to face case).
"03 pad from datum plane and body to datum plane with single sketch item works" => this is ok
"04 pad from datum plane and body to datum plane with two sketch items does not work" => if a second sketch item is added to example 03, it does not appear in the pad. If you change this to a dimension based pad, both items appear. (I think both items should render for the up to face case).
Hope this helps.
OS: macOS High Sierra (10.13)
Version: 0.18.5235 (Git shallow)
Branch: (HEAD detached at 94fa640)
Hash: 94fa64077b748fd2385a83a82e8affffe2ac06db
Python version: 2.7.15
Qt version: 5.11.1
OCC version: 7.2.0
Locale: English/UnitedKingdom (en_GB)
Hope this helps.
Qt version: 5.11.1
OCC version: 7.2.0
- 04 pad from datum plane and body to datum plane with two sketch items does not work.FCStd
- (15.21 KiB) Downloaded 36 times
- 03 pad from datum plane and body to datum plane with single sketch item works.FCStd
- (14.65 KiB) Downloaded 36 times
- 02 pad from xyplane to datum plane with two sketch items does not work.FCStd
- (9.04 KiB) Downloaded 43 times
- 01 pad from xyplane to datum plane with single sketch item works.FCStd
- (8.28 KiB) Downloaded 41 times
- 00 pad from datum plane to xyplane with single sketch item does not work.FCStd
- (8.31 KiB) Downloaded 37 times
Freecad don't support multiple objects in a single sketch.
That's not true. Multiple objects can be created in a sketch. It's only PartDesign that does not currently support multiple solids (for historical and technical reasons). So if padding a sketch would create more than one solid, then it will alert the user. But Part Extrude can generate as many solids as you want.
@vectronic I will try to study your post and files later this weekend.
wmayer wrote: ↑Mon Oct 29, 2018 8:57 am The bug is fixed with git commit fe2660b46 and was part of issue #0003177
Just following up on this again.
Trying with FreeCAD_0.18-15310.c88a64e-OSX-x86_64-Qt5.dmg I still the issue described in my previous comment on this thread and in the simple attached example - The second sketch item does not appear when padding up to face. If you change this to a dimension based pad, both items appear.
The fact it works for a dimension based pad would indicate that what I am trying to do is supported in PartDesign, and that there is a bug related to padding up to face.
I also see the same issue when performing an up to face pocket instead of a dimension pocket (screenshots attached).
OS: macOS 10.14
Version: 0.18.15310 (Git)
Branch: (HEAD detached at c88a64e8e)
Hash: c88a64e8e7a3bb66a23b965b655b5a5040dfa4d2
Qt version: 5.11.2
OCC version: 7.2.0
OS: macOS 10.14
Qt version: 5.11.2
OCC version: 7.2.0
- up to face pocket does not work on multple items in sketch.png (323.28 KiB) Viewed 1601 times
- dimenson pocket works on multple items in sketch.png (353.67 KiB) Viewed 1601 times
- (15.21 KiB) Downloaded 43 times
I guess this is what is intended: The OCCT function that does the right shape wants to have a base feature. For this reason another function was used when no base feature was available. This other function did not support the inclined up to face.NormandC wrote: ↑Thu Sep 07, 2017 4:08 amIt works for me in the following test file. I wonder if it's because the Pad feature is based on an existing solid? I'm afraid I don't have time to test further.freecad-heini-1 wrote: ↑Wed Sep 06, 2017 7:34 am It's impossible to use a datum plane. Is it a bug, or forgotten during development, or should I ask for a feature request?
I tricked the OCCT function doing the right shape into thinking the face defined by the sketch is the base feature. It may well fuse with it. The result is BOP check ok for me.
I am a deep OCCT ignorant, so maybe I broke other things. I will just PR the patch so that somebody who knows better takes a look...
