[Solved] [Feature Request] Rename macro
Sam
Post by Sam »
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11827 (Git)
Build type: None
Hash: ca4488f4387f761df47322038585b23cb5a1bd73
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
It occurred to me that it'd save me some time, and probably a bunch of others, if you were able to rename macros from the macro dialog. A rename button, or F2 on the name.
Not important. Just an idle thought about some polish.
jaisejames
Re: [Feature Request] Rename macro
Post by jaisejames »
+1
Sam
Post by Sam »
Disclaimer: I was fooling around. I have not reviewed the coding standards documentation.
I compiled FreeCAD today because I was hoping to test a couple of patches that haven't been merged yet. But I got distracted.
I have no idea what the local procedure is for this, but here's a patch to rename macros from the macro dialog. I also tidied up the button behaviour a little and clobbered a bit of white space.
It's late, so I'm sure it could do with some rounding out, but it works for me as it is.
0001-Add-a-rename-option-to-the-macro-dialog.patch.txt
(7.2 KiB) Downloaded 57 times
easyw-fc
Post by easyw-fc »
Sam wrote: Wed Aug 30, 2017 1:14 pm I have no idea what the local procedure is for this, but here's a patch to rename macros from the macro dialog.
normally you should clone the FC repo, modify it and make a PR, announcing the PR at the forum as a new topic with the title referring to the PR
Sam
Post by Sam »
Fair enough. I got the impression from the sticky that a PR is kind of the last thing on the agenda.
I'll get my word censored together eventually... :D
BTW, thanks for the stuff you do with kicad!
kkremitzki
Post by kkremitzki »
easyw-fc wrote: Thu Aug 31, 2017 12:18 pm
It isn't really necessary to announce PRs on the Pull Request forum anymore, I believe Yorik and Werner have said they just prefer reviewing stuff on the Github PR itself.
easyw-fc
Post by easyw-fc »
Sam wrote: Thu Aug 31, 2017 12:25 pm BTW, thanks for the stuff you do with kicad!
you are welcome!
thx for the positive feedback :D
It's absolutely sufficient to announce a PR at one place and doing so at several places turned out to be annoying because it's always extra work to accordingly mark the PR when it's merged.
@Sam The easiest for the devs is to make a branch on github but it's also OK to open a report in the bug tracker and attach a patch. When opening a feature request in the forum you should at least put it into the Pull Request section then because due to the amount of posts each day we will easily overlook it there.
Sam
Post by Sam »
wmayer wrote: Thu Aug 31, 2017 6:55 pm It's absolutely sufficient to announce a PR at one place and doing so at several places turned out to be annoying
Understood
wmayer wrote: Thu Aug 31, 2017 6:55 pm @Sam The easiest for the devs is to make a branch on github
Branch rename-macro
wmayer wrote: Thu Aug 31, 2017 6:55 pm When opening a feature request in the forum you should at least put it into the Pull Request section
Fair call. When I asked for this I didn't think I'd be the dude trying to implement it.
I will try to be as cooperative and convenient as possible. But I might not always get it right.
I've turned this thread into a bit of a dogs breakfast now, unfortunately, but I won't make any other noise around the forum about patches/pull requests until I've worked through this one.
PrzemoF
Post by PrzemoF »
Sam wrote: Fri Sep 01, 2017 12:36 am[..]
I will try to be as cooperative and convenient as possible. But I might not always get it right.[..]
If you do-it-yourself it's done exactly as you want it! :D Don't worry about "getting it right" - it's all about learning. My first patch for FreeCAD got a comment: "IMHO your patch does more harm than good" :D
