ickby wrote: ↑Wed Jun 28, 2017 5:51 am
There was annother request recently to allow extruding lines to faces so they can be used as datum for other operation.
Do you mean this topic?
Feature request to work with surfaces
Shapebinder: Normally creates a datum, bit if th elinke dshape is a solid it could be made a real shape by option (possible wit mirroring)
Basically what I was suggesting
so of course I would agree with this!
BTW I found odd behaviour with current ShapeBinder implementation:
- Create Body, add stuff to it (additive Box)
- Deactivate Body, create a second Body (Body001)
- Select Body and create a ShapeBinder in Body001
- Part CheckGeometry on Body001 reports no shape (to be expected I think)
- Create a sketch attached to a face of the ShapeBinder
- Pad: the new Pad is fused with the ShapeBinder
Is it supposed to do that?
Pad/Groove/Revolve: Currently they do not work when one creates a Face with them. But it could be made that they automatically create a datum face if the result is not a solid. Also if it is a solid it could be marked as "datum".
What do you think about this normandc? I think it could help in modeling quite a bit but I'm also afraid this makes it too confusing as the clear lines vanish.
I don't have a strong opinion about this.
It would go against what's been the purpose of the PartDesign wb for years: to only create solids. Jürgen Riegel was planning to add a SurfaceDesign wb to for surface work. But it may take years before there's a complete Surface wb (the curent one only got 2 tools I've never tried).
On the other hand, are we sure this would make things more confusing? Maybe it would actually do the opposite! The Part workbench already allows creation of faces through Extrusion, Revolve, Loft and Sweep; I would say that many new users are confused that PartDesign cannot.
Creating construction/datum shapes is very much essential to advanced design work. If it's done in a separate workbench, it has to be possible to include such shapes in a Body to use them in PartDesign. In the solid modeller I work with, I have access to Surface/construction tools in a separate toolbar. All modelling tools (extrude, revolve, loft, sweep) are duplicated between the "surface" toolbar and the "solid" toolbar. This adds a lot of separate icons. But they are all accessible from the same "workbench".
I wouldn't have said this one year ago, but now I think I would see such a drastic change as beneficial. The important thing is to get more functionality in the PartDesign wb and in FreeCAD in general.
One important thing though: if modelling tools can create faces (what you call datum) in PartDesign, these faces need to be usable. For example, they should be usable with "Up to face" option for Pad/Pocket. Otherwise they serve no purpose that I can see...
And finally one more thing: with the possibility of creating surfaces, next come tools to manipulate those surfaces: trim, extend, stitch (to other faces)... Trust me, they will be requested once you open that door.
How far are you prepared to go?
