issue #0003031: Draft To Sketch should handle bsplines and beziers
Opening an exclusive legit discussion thread to generate discussion about this Feature. The inspiration for the ticket and idea started in https://forum.freecadweb.org/viewtopic. ... 21#p174038
[Solved] Feature #0003031: Draft To Sketch should handle bsplines and beziers
Re: Feature #0003031: Draft To Sketch should handle bsplines and beziers
The only discussion there can be is, who will step up and implement it?
Draft workbench has BSplines and Bézier curves.
Sketch now has B-spline support.
Draft has a Draft2Sketch conversion utility that is only partially working since it strips B-splines and Bézier from the conversion process. This is a legitimate feature request and one that could have indirect uses, like DXF support when exporting sketches containing B-splines...
Yes draft2sketch should definitely handle it. TBH I was (lazily as always) waiting for things to stabilize in Sketch bsplines , since Abdullah seemed still working on it, but it seems that the python interface won't change anymore.
I'll do this when I have a moment. But bezier curves won't be handled. Or there is a way to convert them to bsplines?
At the geometry level, you have :
bspline = bezier.toBSpline(bezier.FirstParameter, bezier.LastParameter)
That is good news, since it improves the compatibility between FreeCAD and inkscape, which I like for it's image tracing capabilities and its usability of bezier curves. The user interface of the Sketcher's bsplines is very promising as well.
Works lik a charm.
Re: [Solved] Feature #0003031: Draft To Sketch should handle bsplines and beziers
