Fasteners workbench based on screw-maker
Giulio Buccini
Re: Fasteners workbench based on screw-maker
Post by Giulio Buccini »
Hallo,
I can add the screws ISO-7380 or ISO-4762 to my project without problems. Nevertheless, if I try to modify the thread-size and/or the lenght, then I get an error:
________
This is what I read in the report view:
19:12:30  Traceback (most recent call last):
  File "/home/giulio/.local/share/FreeCAD/Mod/fasteners/./FastenersCmd.py", line 478, in execute
    s = screwMaker.createFastener(self)
  File "/home/giulio/.local/share/FreeCAD/Mod/fasteners/./ScrewMaker.py", line 428, in createFastener
    return self.createScrew(screwTables[fastenerAttribs.type][FUNCTION_POS], fastenerAttribs)
  File "/home/giulio/.local/share/FreeCAD/Mod/fasteners/./screw_maker.py", line 153, in createScrew
    screw = eval(function)
  File "/home/giulio/.local/share/FreeCAD/Mod/fasteners/./FsFunctions/FSmakeCylinderHeadScrew.py", line 204, in makeCylinderHeadScrew
    headShell = Part.Shell(headFaces)
<class 'Part.OCCError'>: Shape is not a shell
  File "/home/giulio/.local/share/FreeCAD/Mod/fasteners/./FsFunctions/FSmakeButtonHeadScrew.py", line 205, in makeButtonHeadScrew
    screwShell = Part.Shell(headFaces)
19:12:30  Recompute failed! Please check report view.
Any clue? :?
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.21.30377 (Git) AppImage
Hash: 2462f4c7a05745488bb9e81ccc7ba0f386f78849
Locale: English/United States (en_US) [ OS: English/United States (en_US) ]
  * fasteners 0.4.16
  * Curves.backup1666112221.8799047
  * sheetmetal.backup1665679793.2838469
  * sheetmetal 0.2.58
  * A2plus 0.4.59e
  * toSketch 1.0.1
  * Curves 0.5.12
Roy_043
Post by Roy_043 »
Has been reported before. Uninstall the Fastener workbench and then reinstall it.
Giulio Buccini
Uninstall/reinstall the Fastener workbench only, yes? :oops:
Roy_043
Post by Roy_043 »
Sorry for being unclear, I have edited my previous message.
Giulio Buccini
It works now. :)
Thanks!
mario52
Post by mario52 »
Hi @shaise
I have translated (worked with @openBrain ) the text for the language "fr" and "it" and one problem is appeared :
all text contain the
>>> ord("—")
8212
hare not translated , the problem concern all traduction present in "translation" folder
i have modify this character with a simple dash "-" instead "—" for solve the problem
if you hare interested , here the zip with the correction (i change this character by "-"),
the modification for:
(version_fasteners_0-4-24_03-12-2022)
(replace "—" by "-")
FastenersCmd.py
lines 126, 127, 134, 135
    "GOST1144-1": (translate("FastenerCmd", "GOST 1144 (Type 1) Half - round head wood screw"), SlottedGroup, ScrewParametersLC),
    "GOST1144-2": (translate("FastenerCmd", "GOST 1144 (Type 2) Half - round head wood screw"), SlottedGroup, ScrewParametersLC),
    "GOST1144-3": (translate("FastenerCmd", "GOST 1144 (Type 3) Half - round head wood screw"), HCrossGroup, ScrewParametersLC),
    "GOST1144-4": (translate("FastenerCmd", "GOST 1144 (Type 4) Half - round head wood screw"), HCrossGroup, ScrewParametersLC),
(here replace "—" by "-") and compile
compile_qm.py
create_ts.py
fasteners_es-ar.qm
fasteners_es-ar.ts
fasteners_es-es.qm
fasteners_es-es.ts
fasteners_fr.qm
fasteners_fr.ts
fasteners_it.qm
fasteners_it.ts
fasteners_pt-br.qm
fasteners_pt-br.ts
fasteners_pt-pt.qm
fasteners_pt-pt.ts
fasteners_ru.qm
fasteners_ru.ts
files.txt
update.sh
EDIT: 15h09 Paris new version corrected the fr file for translate "Scale" in preferences
EDIT: 04/12/2022 19H14 Paris: adding it language and update "create_ts.py" and "update.sh" abd (fr + it)
now not problem in all language
thanks
mario
Evgeniy
Post by Evgeniy »
@mario52
I can't figure out what kind of error causes a long hyphen?
If from the point of view of grammar, then the standard contains a long dash in the name. And it was just copied as is.
Everything seems to translate perfectly and work.
I can prepare a Pull-Request.
You have a github account?
The fact that you put dots at the end of each line is literate from the point of view of grammar.
But when these lines are displayed in the interface with dots, it looks a little strange.
I strongly recommend that you use the QT Linguist utility, it highlights all questionable or not quite accurate punctuations. Also, with the help of this utility, it is convenient and easy to make a "Release" of the translation.
Also, QT Linguist has detected duplicate strings in your files... you may have done the translation using notepad.
Evgeniy
Post by Evgeniy »
I put the big dash back and as you can see everything translates perfectly. It seems to me that you simply forgot to make a Release at a certain point in the translation or got confused during the translation process.
But I'm a bit confused by the colon signs ":" in the menu. Does it really have to be like this? And somewhere string ends with a dot "." , and somewhere a colon ":" ... It's looks a kind of weird.
Is this normal?
Evgeniy
Post by Evgeniy »
@mario52 you can download and test your fixed translations from here:
https://github.com/FreeCAD-Tools/Fasten ... ranslation
If all ok. I will make Pull - request.
mario52
Post by mario52 »
Hi
for the big dash back the error return with your change
(not forgot to include FastenersCmd.py is also modified see below)
for the ":" , as the original text
for the final point "." and certain ":" ok i have adding you can delete it
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
Locale: French/Mars (fr_MA)
thank for the revision
mario
