Changing Angular Def or Deviation don't recompute
rockn
Post by rockn »
I'm not sure if it's intended but it seem that changing Angular Deflection and/or Deviation in the view property of an object don't tell to FreeCAD that the document have to be recompute.
It need to change a Data property to this change take effect.
Example :
Make a Draft Circle
My default value are
Angular Deflection : 26.5°
Deviation : 0.5%
Change Angular to 1° or Deviation to 0.05%.
No change in the 3d view and the Recompute button is still grayed.
Change the diameter to see the change.
OS: Ubuntu 14.04.2 LTS
Version: 0.16.4805 (Git)
Hash: 3e1e5974f0b064a7e357cd593227c1cd21901bdb
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Formations - Assistance - Développement : https://freecad-france.com
DeepSOIC
Re: Changing Angular Def or Deviation don't recompute
Post by DeepSOIC »
Yeah, same thing. I got used to it.
For the regular deviation to take effect, it's enough to toggle visibility (on my setup, at least). For angular deviation, I see the changes only after forced recompute.
BTW, I would like to suggest to default a deviation to a much finer value for all 2d objects (penalty is very low, while their look at default deviation often sucks).
OS: Windows 8.1
Version: 0.16.4783 +1 (Git)
Branch: unlim_externals
Hash: e37a182c417fa3fe35ad3f7b15709e2f344cafd4
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
rockn
Post by rockn »
DeepSOIC wrote:BTW, I would like to suggest to default a deviation to a much finer value for all 2d objects (penalty is very low, while their look at default deviation often sucks).
Indeed, but AKAIK you can only set default deviation to all FC object not by specific wb object.
rockn
Post by rockn »
Do you think I have to report a bug ? I made a little research and don't find related bug.
rockn
Post by rockn »
NormandC
Post by NormandC »
rockn, is the bug tag not working for you anymore since the forum upgrade?
It still works for me: issue #2059
[bug]2059[/bug]
rockn
Post by rockn »
Not at all ! It work great. In fact I haven't using this tag a lot and have forget it exist ;) I will remember now.
issue #2059
soft bump about issue #2059
DeepSOIC
Post by DeepSOIC »
It's fixed.
DeepSOIC wrote:It's fixed.
In what FC version ?
and who fixed it ?
