Starting having issue with new documents not resizing Origin planes to object/sketches. It ends up having the origin plane within the object, so I have to hide the object to select them.
They work correctly in older files I have created, so it leads me to think I hit some hot key or something that changed how they function now in new documents.
Example of problem when starting a new Sketch in Body in Part Design:
If there isn't an option to change this in FreeCAD, maybe it's just a bug I have ran into with the LinkStage3 build?
Edit:
Adding Versioning info and attaching a file which has the issue.
Version: 2022.709.26244 +5001 (Git)
Branch: LinkDaily
Hash: 096210d21183e9dfdc3b25777760bfb6c00a210b
Python version: 3.8.10
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.2
Issue only started happening late last week, so I am assuming it must be some setting I changed somehow, somewhere.
Origin Planes not Resizing to object
- Basic Standard Empty Spool.FCStd
- (113.39 KiB) Downloaded 35 times
Re: Origin Planes not Resizing to object
Please provide file and full information as described in the link of the big red banner.
Without it it's just guessing.
OK, everything works well on the vanilla version of FreeCAD. I move this to LinkDaily.
vanilla version :
- Basic Standard Empty Spool_SHALM.FCStd
- (94.95 KiB) Downloaded 35 times
- Capture du 2022-09-19 18-01-09.png (30.88 KiB) Viewed 915 times
