Problem in creating a DatumPlane
1- I am creating a master sketch in the XZ plane directly from Sketcher WB.
2- I create a body in PartDeszign WB. From PartDesign, I visualize the Y axis then I select Vertex 1 of the master sketch in order to create a Datum Line passing through Vertex 1 and parallel to Y.
3- Still in PartDeszign WB, I select Vertex 2 of the master sketch then the Datum Line to create a plane passing through 3 points.
Unexpected result:
The Datum Plane, then of course the sketch, show a Y shift of 0.333333 mm.
Where does this come from?
@realthunder , @wmayer
Even if the procedure is not exactly the same, the lag occurs as much in the LinkStage version as in the Master version.
Unexpected result:
- PbDatumPlaneFC_LinkStage.FCStd
- (15.48 KiB) Downloaded 41 times
- PbDatumPlaneFC_0.21.FCStd
- (10.5 KiB) Downloaded 42 times
Re: Problem in creating a DatumPlane
You can see the problem already in the first sketch: Hover over a line of Sketch and see in the status bar that the longer line is between 0 and 4nm off.
@chrisb
Yes but why ? This sketch was constructed in the XZ plane !
I don't think Chris's analysis is correct, the 'real' coords are accurate enough.
- Select the Sketch.
- Ctrl+Shift+P.
- Paste this in the Python console:
[v.Point for v in shp.Vertexes]
- Result:
[ Vector (-25.0, 0.0, 0.0), Vector (68.96926207859083, 7.594372760115067e-15, 34.20201433256686), Vector (58.70865777882078, 1.3853983062116296e-14, 62.39279295614411) ]
@Roy_043
Thank you for your suggestion, but I get this:
Maybe I'm not doing the right thing? or am I doing it wrong?
I imagined that in an XZ plane all points had a (totally) zero Y coordinate...
In any case, the 4 nm shown by @chrisb are far from the 0.333 mm observed for the offset of my DatumPlane.
Python 3.8.6+ (heads/3.8-dirty:a12f459ec2, Nov 5 2020, 12:01:10) [MSC v.1927 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
NameError: name 'shp' is not defined
Sorry, I should have explained that I tested PbDatumPlaneFC_0.21.FCStd in Master.
Version: 0.21.30193 (Git)
Hash: a8cb4e744483ce2c4b0770b948105a766330a4b2
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
I am not sure how attaching something to XZ-plane is actually performed. These deviations look as if this attachment is not done directly, but rather by turning from XY-plane. That may involve some trigonometric functions creating some rounding errors. But even with those is a deviation in the nm range already rather big leave alone the mm.
The test in
The response :
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: French/France (fr_FR)
* A2plusSavTraduc
* Assembly3 0.11.3
* BIM 2021.12.0
* BOLTSFC
* Curves 0.5.5
* DynamicData 2.46.0
* fasteners 0.4.2
* fcgear 1.0.0
* IconThemes
* PieMenu
* symbols_library
Python 3.10.6 | packaged by conda-forge | (main, Aug 22 2022, 20:30:19) [MSC v.1929 64 bit (AMD64)] on win32
I agree.
But it's only in this plan construction method that I've noticed this type of discrepancy.
- adrianinsaval
Did you actually select the sketch and press ctrl+shift+p? If that doesn't work try right click->send to python console
