development/toponaming branch fails to build on Debian 11
user1234
Post by user1234 »
Hello!
@realthunder: today i saw that there are some new commits in the development/toponaming branch. So i tried to build it, but it fails (also made a new clean build).
[ 44%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_Mesh.cpp.o
In file included from /home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasherPyImp.cpp:25:
/home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasher.h: In member function ‘bool App::StringID::isFromSameHasher(const StringHasherRef&) const’:
/home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasher.h:93:30: error: ambiguous overload for ‘operator==’ (operand types are ‘App::StringHasher* const’ and ‘const StringHasherRef’ {aka ‘const Base::Reference<App::StringHasher>’})
   93 |         return this->_hasher == hasher;
      |                      |          const StringHasherRef {aka const Base::Reference<App::StringHasher>}
In file included from /home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasher.h:33,
/home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/Base/Handle.h:137:10: note: candidate: ‘bool Base::Reference<T>::operator==(const Base::Reference<T>&) const [with T = App::StringHasher]’ (reversed)
  137 |     bool operator==(const Reference<T>& p) const {
/home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasher.h:93:30: note: candidate: ‘operator==(App::StringHasher*, App::StringHasher*)’ (built-in)
make[2]: *** [src/App/CMakeFiles/FreeCADApp.dir/build.make:293: src/App/CMakeFiles/FreeCADApp.dir/StringHasherPyImp.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
[ 44%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MeshEditor.cpp.o
[ 44%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MeshAlgos.cpp.o
[ 44%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MeshVSLink.cpp.o
In file included from /home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringIDPyImp.cpp:25:
make[2]: *** [src/App/CMakeFiles/FreeCADApp.dir/build.make:306: src/App/CMakeFiles/FreeCADApp.dir/StringIDPyImp.cpp.o] Error 1
[ 44%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_MesherHelper.cpp.o
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_Octree.cpp.o
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_OctreeNode.cpp.o
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_Pattern.cpp.o
[ 45%] Linking CXX shared library ../../../../Mod/Path/area.so
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_ProxyMesh.cpp.o
[ 45%] Built target area
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_TryCatch.cpp.o
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/SMESH_subMesh.cpp.o
[ 45%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/Utils_ExceptHandlers.cpp.o
In file included from /home/user/Programs/FreeCADdevelopmenttoponaming/sourcecode/src/App/StringHasher.cpp:45:
make[2]: *** [src/App/CMakeFiles/FreeCADApp.dir/build.make:280: src/App/CMakeFiles/FreeCADApp.dir/StringHasher.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:2617: src/App/CMakeFiles/FreeCADApp.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 45%] Building C object src/3rdParty/salomesmesh/CMakeFiles/SMESH.dir/src/SMESH/libmesh.c.o
[ 45%] Linking CXX shared library ../../../lib/libSMESH.so
[ 45%] Built target SMESH
make: *** [Makefile:149: all] Error 2
real	1m27.920s
user	15m40.213s
sys	1m26.376s
System: Debian 11
OCCT: 7.6.3
Compiler: GCC10 (set in cmake to C++20)
If something other info is missing, please let me know.
Greetings
user1234
user1234
Re: development/toponaming branch fails to build on Debian 11
Post by user1234 »
Forgot to mention:
-DBUILD_FLAT_MESH = 1
Greetings
user1234
realthunder
Post by realthunder »
Can you please manually apply the patch here, and try again.
user1234
Post by user1234 »
realthunder wrote: Sun Sep 04, 2022 6:37 am Can you please manually apply the patch here, and try again.
Thanks! Compiles fine! Testing must wait. Just asking, is there something i should look specific when testing?
Greetings
user1234
Tested with clang++ 11 and C++17 (I don't have C++20 available here) and this compiles fine.
Not sure if the issue you have is because of the different compilers or the different C++ standard. But the use of the comparison in isFromSameHasher is indeed odd because it uses a raw pointer of StringHasher and compares it with a StringHasherRef.
I guess the gcc compiler tries these two options:
  • Convert the StringHasher* into a StringHasherRef (by using the constructor) to do the comparison or
  • Convert the StringHasherRef into a StringHasher* (because there is a suitable operator defined in Base::Reference) to do the comparison.
and thus raises the ambiguity error.
IMO it's the actually the implementation of isFromSameHasher to blame and this should be fixed instead of modifying Base::Reference.
Does it work to change it to
    bool isFromSameHasher(const StringHasherRef & hasher) const
        return this->_hasher == static_cast<StringHasher*>(hasher);
Additionally, it should be avoided that a StringHasher* can be implicitly converted into a StringHasherRef and therefore the constructor of Base::Reference should be declared as explicit. When doing so then an overloaded version of reset(T*) is needed.
user1234
Post by user1234 »
wmayer wrote: Sun Sep 04, 2022 5:22 pm Tested with clang++ 11 and C++17 (I don't have C++20 available here) and this compiles fine.
This is the reason why i noted the compiler, since the gitlab CI compile check is OK and i did no see anything odd in the log from it.
wmayer wrote: Sun Sep 04, 2022 5:22 pm Does it work to change it to
Can only test it in a few days.
Greetings
user1234
