Imported reference from another body results in duplicated geometry in second body
dentex_YTD
Post by dentex_YTD »
Hello, this is the FreeCAD version I'm using:
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 2022.704.26244 +4971 (Git) AppImage
Branch: LinkDaily
Hash: a87320cc64699a8e4226bad2e9b37ac3a1296ab9
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Maybe the title is not very clear, sorry.
What happens is this:
I make a body, a sketch and a simple pad.
Then I make a new body (now active), a new sketch, and reference an edge from the previous pad to attach some new geometry.
Now, the geometry from the 1st body gets duplicated into the 2nd one, and i.e. I cannot export them as separate STLs.
Here is a screenshot.
Schermata del 2022-08-18 12-32-56.png (55.22 KiB) Viewed 699 times
Test file attached.
Thanks in advance for any help.
example.FCStd
(23.69 KiB) Downloaded 26 times
Re: Imported reference from another body results in duplicated geometry in second body
Moved from Help forum.
If you use the Link branch, post here.
dentex_YTD
chrisb wrote: Thu Aug 18, 2022 11:08 am Moved from Help forum.
Thank you. Sorry if I missed the correct subforum.
