Transparent mode background question
I'm trying to get clean look for my freecad and tried several tutorial but not getting there. Everything works, except for combo view background. It's not completely transparent when the mouse is over the 3d view, however once I hover over combo view, background becomes transparent. How can I get to be always transparent?
Re: Transparent mode background question
@realthunder could you please help me debug the problem?
Preference -> General -> Overlay style sheet, selection 'Dark-Outline'.
Yep, I have that selected.
It's the same for 2022.04.03 release and 2022.07.04
But side panel looks terrible until I hover over it.It's the same for 2022.04.03 release and 2022.07.04
del
@realthunder that doesn't help. I already have this setting selected, but side panel looks as above
I don't quite understand. I mean your screenshoot below is transparent. Or do you mean when you mouse over it, it because not transparent? Can you please capture a screencast showing the problem? Can you also post your FreeCAD About information here? And your user configurations, Tools -> Edit parameters -> Exportakshimassar wrote: ↑Mon Jul 11, 2022 7:36 pm @realthunder that doesn't help. I already have this setting selected, but side panel looks as above
- bbb.png (68.01 KiB) Viewed 2167 times
Here is the video. It's transparent only when mouse is over it.OS: Arch Linux
Version: 2022.709.28846 (Git) AppImage
Branch: LinkStage3
Hash: c880c050c5f7601e4bae6740de71500edf2be0c7
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
https://youtu.be/ihsqLMXfW6I
Exported parameters attached as
Disable the following option to get the correct behavior. This option is obsolete. I'll remove it.
Thank you so much! Works like a charm!
