Dynamic Model -irregular movement across Screen
Outsourced
Post by Outsourced »
Hello FreeCAD
I hope you're well, Please find the file attached.
Bug Description:- Open Slider 'Rope' click the slider to use the arrows on the keyboard, Watch how the entire model is relocated on the screen.
Please be advised it is unlikely this model will load in anything other than LS3.430
Prior to sending I've closed & Re-opened & discovered something has failed but it shouldn't effect the bug description.
Kind Regards
Clark Cuant
LS3.430_B507_I14_22.06.22A.FCStd
(117.27 KiB) Downloaded 27 times
Re: Dynamic Model -irregular movement across Screen
Outsourced wrote: Wed Jun 22, 2022 1:26 am Please be advised it is unlikely this model will load in anything other than LS3.430
then it's better to post in the link branch forum: https://forum.freecadweb.org/viewforum.php?f=44
Outsourced
Because its unclear to where the error is coming from is it an LS3 or a workbench issue,
It has been upgraded to a ticket in the FC developers hub.
Thx for your help.
Moved the topic.
Outsourced wrote: Wed Jun 22, 2022 1:26 am Open Slider 'Rope' click the slider to use the arrows on the keyboard, Watch how the entire model is relocated on the screen.
Do you have anything else attached to a USB port? We have seen cumbersome things when e.g. a gaming console or a joystick was attached.
bambuko
Post by bambuko »
16:03:29  <class 'ModuleNotFoundError'>: No module named 'freecad.mnesarco'
16:03:29  <class 'ModuleNotFoundError'>: No module named 'Asm4_libs'
??? :roll: :oops: :cry:
You didn't say anything about Assembly4 ?
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 2022.622.14555 (Git shallow)
Branch: (HEAD detached at 2022.06.22-edge)
Hash: 1dd47fd7ecdcd8d5f776ced0a702a7a7dc5d4ee5
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
