and a final outcome (what it was all about )
using Assembly 3
Thank you for your help !!!
cam following options (solved)
Re: cam following options (solved)
Would you mind sharing the final model?
Not at all. Attached is the version with the spring washer offset off centre (as per https://forum.freecadweb.org/viewtopic. ... 67#p592337)
Originally and as shown on .gif it is central.
I use a macro to rotate it continuously, but you can also rotate it manually to any specific angle using Dynamic Data
(part of the design - I use DD a lot. Like it very much!)
Enjoy! any questions - shout
