CMake shows OpenMP installed but isn't part of PrintFinalReport.cmake
Running CMake I see:
-- Found OpenMP_C: -fopenmp (found version "4.5")
-- Found OpenMP_CXX: -fopenmp (found version "4.5")
But when I reach the summary report, no mention of OpenMP at all.
I think we should add it.
This report is accurate for r28697
$ git rev-list --count HEAD
28697
Background: "The OpenMP API supports multi-platform shared-memory parallel programming in C/C++ and Fortran." https://www.openmp.org/
waebbl
Re: CMake shows OpenMP installed but isn't part of PrintFinalReport.cmake
Post by waebbl »
Kunda1 wrote: Thu Apr 14, 2022 10:14 pm Running CMake I see:
Is OpenMP actually used directly by FreeCAD? The output might come from some third-party CMake files, i.e. I know, that VTK can have support for OpenMP and checks for the package. In such cases, I would not add it to the final report.
waebbl wrote: Fri Apr 15, 2022 9:39 am Is OpenMP actually used directly by FreeCAD?
https://github.com/FreeCAD/FreeCAD/blob ... s.txt#L202
which openmp package are we using from this list? https://repology.org/projects/?search=o ... es_newest=
openBrain
Post by openBrain »
Kunda1 wrote: Fri Apr 15, 2022 12:03 pm which openmp package are we using from this list? https://repology.org/projects/?search=o ... es_newest=
$ ldd bin/FreeCAD | grep openmp
        libhdf5_openmpi.so.103 => /lib/x86_64-linux-gnu/libhdf5_openmpi.so.103
Then (for Debian derivatives) :
$ dpkg -S libhdf5_openmpi.so.103
libhdf5-openmpi-103-1:amd64: /usr/lib/x86_64-linux-gnu/libhdf5_openmpi.so.103.2.0
openBrain wrote: Fri Apr 15, 2022 12:10 pm
Thanks! Odd I don't see a *hdf5* version that matches our v4.5
Unless ours is very outdated?
openBrain
Post by openBrain »
Kunda1 wrote: Fri Apr 15, 2022 12:53 pm Thanks! Odd I don't see a *hdf5* version that matches our v4.5
https://repology.org/project/hdf5-openmpi4/versions :?:
openBrain wrote: Fri Apr 15, 2022 12:56 pm
Weird, the version is way off
openBrain
Post by openBrain »
Kunda1 wrote: Fri Apr 15, 2022 1:27 pm Weird, the version is way off
I'm not so familiar with Suse, but I guess this is the package version, that you compare with the lib version. ;)
Generally when the package says "openmpi4", it is ... version 4 :)
chennes
Post by chennes »
I think you're confusing OpenMP and OpenMPI -- although they sound similar, they are actually totally different parallelization strategies. FEM uses OpenMP (look for #pragma omp statements).
Chris Hennes
Pioneer Library System
