conda images, some questions.
Hello, I have some question about conda package.
i have used the fcenv-dev miniconda package and I'm perfectly satisfied, but I've noted that when I make a periodic update many packages could be "downgraded".
What is the correct way to update the fcenv-dev miniconda environment.
I use:
conda update -n fcenv-dev freecad
TIA for any advice and explanation.
feel free to ask about my configuration, but be patient as I'm rather new to miniconda.
My English and Italian Scripting Guide https://github.com/onekk/freecad-doc.
My Blog: https://onekk-maker.blogspot.com/
To help development see on GitHub Page
For enquiry about customized FC Scripting job PM me.
Re: conda images, some questions.
looo wrote: pinged by pinger macro
#lowhangingfruit | Use the Source, Luke. | How to Help FreeCAD | How to report FC bugs and features
looo
Post by looo »
If a lot of packages are downgraded, maybe your channel settings have changed. I didn't see anything like this happening for me for a long time.
If you have added the channels to the config, the FreeCAD/label/dev channel should appear on top of the conda-forge channel. If you haven't got the freecad/label/dev channel in your config you can add it via:
conda config --add channels freecad/label/dev
to check your channels you can use (iicrc)
conda config --show channels
this should result in
channels:
  - freecad/label/dev
  - conda-forge
or similar.
to update all I use:
conda activate fcenv-dev
conda update --all
You can also add the channel in the update command like
conda update --all -c freecad/label/dev
if you do not have them in the config.
