conda win build fails
looo
Post by looo »
Not sure if this is a temporary issue:
%SRC_DIR%\src\Base\ConsoleObserver.cpp(121): error C2039: 'SetConsoleTextAttribute': is not a member of '`global namespace''
%SRC_DIR%\src\Base\ConsoleObserver.cpp(121): error C2039: 'GetStdHandle': is not a member of '`global namespace''
%SRC_DIR%\src\Base\ConsoleObserver.cpp(121): error C2065: 'STD_ERROR_HANDLE': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(121): error C3861: 'GetStdHandle': identifier not found
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C2039: 'GetStdHandle': is not a member of '`global namespace''
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C2065: 'STD_ERROR_HANDLE': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C3861: 'GetStdHandle': identifier not found
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C2065: 'FOREGROUND_RED': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C2065: 'FOREGROUND_GREEN': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(163): error C3861: 'SetConsoleTextAttribute': identifier not found
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2039: 'SetConsoleTextAttribute': is not a member of '`global namespace''
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2039: 'GetStdHandle': is not a member of '`global namespace''
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2065: 'STD_ERROR_HANDLE': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C3861: 'GetStdHandle': identifier not found
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2065: 'FOREGROUND_RED': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2065: 'FOREGROUND_GREEN': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C2065: 'FOREGROUND_BLUE': undeclared identifier
%SRC_DIR%\src\Base\ConsoleObserver.cpp(173): error C3861: 'SetConsoleTextAttribute': identifier not found
