I would like to run AppImageUpdate automatically so that I can always have the latest weekly build (as a cron job) but I am running into an issue with AppImageUpdate-x86_64.AppImage.
When running AppImageUpdate the update process is running as expected and a new AppImage file is successfully written. But the process never exits and have to be stopped with Ctrl-C. This is fine for manual use, but if run from a script it is inconvenient.
I have seen this issue discussed before in the forum. But I could not see the resolution. Any good ideas?
Below I try to update the LinkStage3 fork, but issue seems to be the same for all AppImages.
david@swift:~/Apps$ ./AppImageUpdate-x86_64.AppImage FreeCAD-asm3-Daily-Conda-Py3-Qt5-20210226-glibc2.12-x86_64.AppImage
AppImageUpdate version 1-alpha (commit cb611d8), build 431 built on 2020-04-07 21:47:19 UTC
Fetching latest release information from GitHub API
Updating from GitHub Releases via ZSync
zsync2: Target file: /home/david/Apps/FreeCAD-asm3-Daily-Conda-Py3-Qt5-20220111-glibc2.12-x86_64.AppImage
zsync2: Reading seed file: /home/david/Apps/FreeCAD-asm3-Daily-Conda-Py3-Qt5-20210226-glibc2.12-x86_64.AppImage
zsync2: Usable data from seed files: 20,325109%
zsync2: Renaming temp file
zsync2: Fetching remaining blocks
zsync2: Downloading from https://objects.githubusercontent.com/github-production-release-asset-2e65be/103059612/df671083-3fe2-44b3-9b44-e64348b2b667?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20220116%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20220116T093127Z&X-Amz-Expires=300&X-Amz-Signature=c182fe6ccb590e66889cf86268a8fae6e2bb0d8674e28a90ad51f3838683cbfe&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=103059612&response-content-disposition=attachment%3B%20filename%3DFreeCAD-asm3-Daily-Conda-Py3-Qt5-20220111-glibc2.12-x86_64.AppImage&response-content-type=application%2Foctet-stream
zsync2: optimized ranges, old requests count 468, new requests count 72
zsync2: Verifying downloaded file
zsync2: checksum matches OK
zsync2: used 187650048 local, fetched 754468032
^C
